EDP转换IC NCS8803:HDMI转EDP芯片
1322|1
 楼主| TEL13530609500 发表于 2022-6-23 17:41 | 显示全部楼层 |阅读模式
HDMI-to-eDP Converter w/ scaler
1 Features
    Embedded-DisplayPort (eDP) Output
    1/2/4-lane eDP @ 1.62/2.7Gbps per lane
    HD to WQXGA (2560*1600) supported
    Up to 6dB pre-emphasis
HDMI Input
    HDMI 1.4a supported
    RGB444/YCbCr444/YCbCr422 supported
    Pixel clock up to 340MHz
    2-channel audio supported
    Support Hot-Plug Detect
    Adaptive equalization
Reference Clock
    Any freq. between 19MHz and 100MHz
    Crystal or single-ended clock input
    Built-in 5000ppm SSC generator
Misc
    I2C for chip configuration
    Built-in eDP handshake protocol
    I2C-AUX channel for TCON/DPCD/EDID control
    Built-in video test pattern
Power
    1.2V core supply
    2.5V or 3.3V IO supply
    Power consumption ~ 150mW
    @ 2560*1600*24bit*60Hz
    Deep-sleep mode power <1mW
Package
    QFN-56 (7mm x 7mm) package
    RoHS Compliant
    Sample available now
2 Block Diagram1
3 General Description
    NCS8803 is a low-power HDMI-to-DisplayPort/eDP converter with advanced scaling function, fractional scaling ratio from 2:1 to 1:2, which is designed for mobile devices including tablets, laptops, monitor, etc. to support high-definition DP/eDP displays.
    NCS8803 supports 4-lane DP/eDP output which is typically required to support WQXGA (2560*1600) and above at 60Hz frame rate.
    Thanks to our proprietary scaling algorithm, NCS8803 provides high picture quality. All the functions pack into a small 7mm*7mmQFN56 package which saves the precious space in mobile devices.
4 Pin Diagram
 楼主| TEL13530609500 发表于 2022-8-24 09:12 | 显示全部楼层
不错吃 ,好的方案,好的分享。
