【TYPE-C方案】NCS8823:TYPE-C转VGA功能说明
834|0
 楼主| TEL13530609500 发表于 2022-6-23 17:55 | 显示全部楼层 |阅读模式
NCS8823:TYPE-C to VGA Converter
1 Features
VGA Output
Up to 1920x1080@60Hz supported
Compliant with VESA VSIS 1.2
R/G/B swappable
Load sensing
5V tolerance DDC I/Os
TYPE_C Input
Compliant with VESA DisplayPort Alt Mode
On USB Type-C srandard V1.0
Compliant with USB Power Delivery Specifi--cation R2.0, v1.0
Compliant with USB Type-C Cable and Co--nnector specificationR1.2
Compliant with HDMI 1.4b Alt Mode on USB Type-C specification V1.0
Compliant with DP Alt Mode 1.0 , PD 2.0 Type-C, HDMI 1.4b Alt Mode 1.0
Built-in dual CC controllers for charger and normal communication
Roles supported:UFP(sink)
Clock
Refless clock system
Misc
selectable I2C slave
Firmware update through SPI,I2C,AUX interface
Built-in video test pattern
Power
1.2V core supply
2.5V or 3.3V IO supply
Power consumption ~ 150mA
Deep-sleep mode power <1mW
Package
QFN-32 (4mm x 4mm) package
RoHS Compliant
2 Block Diagram
3 General Description
NCS8823 is a low-power and high performance Type-C Alt Mode 1.2 to VGA converter, designed to connect a USB Type-C source to a VGA sink.
The NCS8823 integrates a DP1.2 compliant receiver, and a high-speed triplechannel video DAC. Also, two CC controllers are included for CC communication to implement DP Alt Mode and power delivery function, one for upstream Type-C port and another for downstream port.
Two digital audio output interfaces are available, I2S and SPDIF. The I2S interface supports 2-ch LPCM and the SPDIF interface supports 8-ch LPCM or compressed audio,both at maximum 192kHz sample rate.
All the functions pack into a small 4mm*4mmQFN32 package which saves the precious space in mobile devices.
4 Pin Diagram
5 Pin Description
6 Electrical Specifications
6.1 Operating Conditongs
6.2 Power Consumptoin
6.3 eDP Main Channel EIectrical Specification
6.4 Edp AUX channel EIectrical Specifications
6.5 Type-c Electrical Specification
7 Register Table
