[通用8051核FLASH系列] HC89S003F4管脚快速设置
1699|8
 楼主| cehuafan 发表于 2022-6-30 09:11 | 显示全部楼层 |阅读模式
/******管脚设置函数 by abin******/
#define P00  0
#define P01  1
#define P02 2
#define P03 3
#define P04 4
#define P05 5
#define P06 6
#define P07 7
#define P20 20
#define P21 21
#define P22 22
#define P23 23
#define P24 24
#define P25 25
#define P26 26
#define P27 27
#define P10 10
#define P11 11
#define IO_IN_FL_NO_SMT 0x00   //!<0000输入(无SMT)
#define IO_IN_PD_NO_SMT 0x01   //!<0001带下拉输入(无SMT) P2.3/P2.4/P2.5/P2.7不支持此功能
#define IO_IN_PU_NO_SMT 0x02   //!<0010带上拉输入(无SMT) P2.3/P2.4/P2.5/P2.7不支持此功能
#define IO_IN_AN  0x03   //!<0011带模拟输入
#define IO_IN_SMT  0x04   //!<0100输入(SMT)
#define IO_IN_PD_SMT  0x05   //!<0101带下拉输入(SMT)
#define IO_IN_PU_SMT  0x06   //!<0110带上拉输入(SMT)
#define IO_IN_AN_PU_PD 0x07   //!<0111带上下拉模拟输入  仅P2.3/P2.4/P2.5/P2.7支持此功能
#define IO_OUT_PP  0x08   //!<1x00推挽输出
#define IO_OUT_OD  0x09   //!<1x01开漏输出
#define IO_OUT_PU  0x0A   //!<1x10带上拉开漏输出
//P2M1 = P2M1&0x0F|0x80;  //P23设置为推挽输出
//GPIO(P23,IO_OUT_PP);
void GPIO(u8 m,u8 n)  //HC89S003F4管脚快速设置函数by abin 。 m为管脚 P0.1=01  P1.0=10 等,n为管脚状态,见上面或数据手册说明
switch (m)
case 00:P0M0 = P0M0&0xF0|n;break;
case 01:P0M0 = P0M0&0x0F|(n*16);break;
case 02:P0M1 = P0M1&0xF0|n;break;
case 03:P0M1 = P0M1&0x0F|(n*16);break;
case 04:P0M2 = P0M2&0xF0|n;break;
case 05:P0M2 = P0M2&0x0F|(n*16);break;
case 06:P0M3 = P0M3&0xF0|n;break;
case 07:P0M3 = P0M3&0x0F|(n*16);break;
case 20:P2M0 = P2M0&0xF0|n;break;
case 21:P2M0 = P2M0&0x0F|(n*16);break;
case 22:P2M1 = P2M1&0xF0|n;break;
case 23:P2M1 = P2M1&0x0F|(n*16);break;
case 24:P2M2 = P2M2&0xF0|n;break;
case 25:P2M2 = P2M2&0x0F|(n*16);break;
case 26:P2M3 = P2M3&0xF0|n;break;
case 27:P2M3 = P2M3&0x0F|(n*16);break;
case 10:P1M0 = P1M0&0xF0|n;break;
case 11:P1M0 = P1M0&0x0F|(n*16);break;
default:break;
        P2M0 = P2M0&0x0F|0x80;                                //P21设置为推挽输出
        GPIO(P21,IO_OUT_PP);
        P0M1 = P0M1&0x0F|0x20;                                //P03设置为上拉输入
        GPIO(P03,IO_IN_PU_NO_SMT);
原文链接:https://blog.csdn.net/silno/article/details/80412869
1123506 发表于 2022-6-30 11:26 | 显示全部楼层
您好我是芯圣代理 需要芯圣芯片可以联系QQ2914373240  003低价抛售
tpgf 发表于 2022-7-4 15:27 | 显示全部楼层
这个是自己写的吗
您好我这边是上海芯圣一级代理做上海芯圣芯片的有需要请加QQ2914373240  发表于 2022-7-7 13:26
nawu 发表于 2022-7-4 15:35 | 显示全部楼层
这个分支好多呀
aoyi 发表于 2022-7-4 15:45 | 显示全部楼层
代码量多了 但是处理起来快了
zljiu 发表于 2022-7-4 16:02 | 显示全部楼层
完全的自己设定的吗
gwsan 发表于 2022-7-4 16:09 | 显示全部楼层
这样做的优势是什么呢
tfqi 发表于 2022-7-4 16:18 | 显示全部楼层
直接做乘**不会降低效率啊
