MounRiver Studio下载程序错误
1987|4
 楼主| rand2015 发表于 2022-7-2 08:44 | 显示全部楼层 |阅读模式
------------ Begin flash process of "obj\GPIO_Toggle.hex" ------------
08:41:20:512 >> Current project vendor is WCH, debugger is WCH-Link
08:41:20:513 >> Attempt to open device and upgrade firmware if necessary...
08:41:20:517 >> WCH-Link no need to upgrade. Already the latest version.
08:41:20:557 >> Starting to Send Chip Type...
08:41:20:569 >> Not support this packaged chip type
08:41:20:569 >> Starting to Close Link...
08:41:20:569 >> Close Link Success
有知道原因的吗,谢谢!
tyw 发表于 2022-7-2 08:52 | 显示全部楼层
qq172179 发表于 2022-7-2 14:37 | 显示全部楼层
你这应该是开启读报护了,关了就好。
HARRY007 发表于 2022-7-2 16:58 | 显示全部楼层
你这是V1.8吗?我也遇到了,装了V1.7好了……没深究
tototm 发表于 2022-7-3 11:11 | 显示全部楼层
我的是V1.8,暂时没有出现问题,可以把WH_LINK从新设置一下成下载RISC-V芯片而非ARM芯片
