 Wallys network card QCA9880 QCN9074 MT7915 MT7975
 DR900vx/DR600VX QCA9880 QCA9882 Qualcomm-Atheros QCA9880 chipset
 2.4GHz max 26dBm & 5GHz max 25dBm output power
 IEEE  802.11ac compliant & backward compatible with 802.11a/b/g/n
 3x3 MIMO Technology, up to 1.3Gbps
 Mini PCI Express edge connector
 RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
 Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
 Combining (MRC), Space Time Block Code (STBC)
 Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
 Supports Dynamic Frequency Selection (DFS)
 FCC,CE and IC Certification
 DR9074-6E(PN02.7) DR9074-5G(PN02.1) QCN9074 QCN9024 QCN9072■ Qualcomm Atheros [QCN9074]
 ■ 6GHz, max 23dBm per chain, up to 4949Mbps
 ■ Single Band 6GHz 4x4 [WiFi 6E (802.11ax)]
 ■ 4 spatial streams (4SS)
 ■ M.2 E Key Interface
 ■ PCI Express 3.0 Interface
 **DR7915 MT7915 MT7975 **
 MT7915+MT7975 Chipset
 2.4GHz max 23dBm & 5GHz max 35dBm output power
 IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
 2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
 SupporttheFrequency2412MHz~2482MHz
 SupporttheFrequency5180MHz~5825MHz
 Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
 CardsareindividuallycalibratedforQualityAssurance
 Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook. welcome to consult.
