429|16
zwll|  楼主 | 2022-7-10 11:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PIC18F67K22想使用定时器0中断,并且配置LED2一秒钟变化一次,时钟想配置内部16M,现在的问题是LED2用示波器观测时1.12秒变化一次
supernan| | 2022-7-10 11:28 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
zwll|  楼主 | 2022-7-10 11:30 | 只看该作者
/********************部分配置字
#pragma config RETEN = ON
#pragma config INTOSCSEL = HIGH
#pragma config SOSCSEL = DIG
#pragma config XINST = OFF
// CONFIG1H
#pragma config FOSC = INTIO2
#pragma config PLLCFG = OFF
#pragma config FCMEN = OFF
#pragma config IESO = OFF
// CONFIG2L
#pragma config PWRTEN = OFF
#pragma config BOREN = SBORDIS
#pragma config BORV = 3         // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF      // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 16  // Watchdog Postscaler (1:1048576)
// CONFIG3L
#pragma config RTCOSC = INTOSCREF // RTCC Clock Select (RTCC uses INTOSCREF)
// CONFIG3H
#pragma config CCP2MX = PORTC   // CCP2 Mux (RC1)
#pragma config MSSPMSK = MSK7   // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON       // Master Clear Enable (MCLR Enabled, RG5 Disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K     // Boot Block Size (2K word Boot Block size)
/************************时钟配置部分
IRCF2 = 1;
    IRCF1 = 1;
    IRCF0 = 1;        //内部16M时钟
    SCS1 = 1;
    PLLEN = 0;        //不4倍频
    SOSCRUN = 0;
    MFIOSEL = 0;
    //OSCTUNE = 0X80;
    while(!HFIOFS);
/***********************定时器配置部分
void Time0InitConfig()
    T08BIT = 0;        //16位定时器
    T0CS = 0;        //内部1/4FOSC时钟
    T0PS2 = 0;
    T0PS1 = 0;
    T0PS0 = 1;        //预分频器1/4分频
    PSA = 0;        //设置使用预分频器的频率
    TMR0L = 0x9c;
    TMR0H = 0xff;
    //TMR0 = 156;        //定时100us
    TMR0IE = 1;        //启动中断
    TMR0ON = 1;        //开启定时器中断
    TMR0IF = 0;
/************定时器中断
void Tmr0Interrupt_ISR()
    static uint x;
    if(TMR0IF == 1)
        TMR0IF = 0;
        TMR0L = 0x9c;
        TMR0H = 0xff;
        BeepWork();
        x++;
        if(x <= 10000)
            LED2 = 0;
        else if(x <= 20000)
            LED2 = 1;
        else
            x = 0;
wyjie| | 2022-7-10 11:34 | 只看该作者
先别累加, 看看一次中断的测量值和理论值各是多少?
juventus9554| | 2022-7-10 11:37 | 只看该作者
定时器可以0.5s中断一次呀。
dingy| | 2022-7-10 11:40 | 只看该作者
建议用MCC配置和生成基本的程序,自己再修改。
xxrs| | 2022-7-10 11:43 | 只看该作者
可能是时钟误差
zhanghqi| | 2022-7-10 11:45 | 只看该作者
这个原因应该是从中断触发到在中断里面重新赋值TMR0L = 0x9c; TMR0H = 0xff的延迟引起; 这是因为进入中断以及中断中执行到TMR0赋值指令都是需要时间的。
chuxh| | 2022-7-10 11:48 | 只看该作者
这个延迟时间应该就是112-100=12uS. 你可以将Timer的时基变大,例如256分频。
dingy| | 2022-7-10 11:49 | 只看该作者
另外尽量将中断周期加长,使TMR0的值尽可能小,这样周期就得到加长,最好是直接1秒中断一次。在256分频时,取TMR0=0xC2F7应该可以了。
dengdc| | 2022-7-10 11:52 | 只看该作者
我看你用的内部16M啊,外部的4M用了吗?
llljh| | 2022-7-10 12:00 | 只看该作者
如果是内部的 时钟误差 + 中断延迟 + 指令执行时间 差不多吧
pengf| | 2022-7-10 12:03 | 只看该作者
为啥不尝试MCC生产代码??
heweibig| | 2022-7-10 12:05 | 只看该作者
简单又实用~~~还不用你这样来回折腾.....
zwll|  楼主 | 2022-7-10 12:08 | 只看该作者
这个~没说是要1S延时,要100us,1s我是用来测试的
jlyuan| | 2022-7-10 12:10 | 只看该作者
楼主还可以提高主频试试,还可以调整编译器的优化等级看看,  没其他太好的办法
zwll|  楼主 | 2022-7-10 12:13 | 只看该作者
其实还是不大明白,我再琢磨琢磨吧,多谢了哈先
