[无线通信] Wallys ROUTERBOARD DR6018(CP01)
1414|0
 楼主| wallysJane 发表于 2022-7-11 11:29 | 显示全部楼层 |阅读模式
Wallys Communications (Suzhou ) Co., LTD(https://www.wallystech.com/)
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
In the complex market, Wallys products stand out and are affirmed by partners. From 802.11 a - ax, Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344/AR9531
Contact:sales1@wallystech.com
IPQ6018 802.11ax   2x2 2.4GHz&5GHz 1xM.2 E key
Features
Qualcomm-Atheros IPQ6018
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Sample Price:200USD/pcs
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48
    V
    Operating Temperature Range
    -40 to +70
    ºC
    Storage Temperature Range
    -45 to +105
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    5x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
    SD Card Slot
    1x SD Card Slot
    USB /header
    1x USB 2.0 Port, 1x USB 3.0 Type-C Port
    POE
    24V~48V passive POE
    DC Jack
    12V power supply
    LED header
    FFC/FPC Connector
    Serial Port
    1x Serial Port 12 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/802.11n/802.11ac/802.11ax, max 20dBm per chain
    4x U.FL Connectors
    Nor Flash
    32MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension (W x H x D)
    219mm x 150mm x 16.5mm (Without Heatsink)
