GD32F303RE SPI0无数据输出
998|8
zhanxiao|  楼主 | 2022-7-13 09:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用GD32F303RET6,接SPI flash GPA4和GPC4作为两个SPI FLASH的片选脚,PA5,PA6,PA7为SPI pin,发现除了CS有变化,SPI的MOSI MISO SCLK都没有波形,代码如下,请高手点拨一下。
        rcu_periph_clock_enable(RCU_GPIOA);
        rcu_periph_clock_enable(RCU_GPIOB);
        rcu_periph_clock_enable(RCU_GPIOC);
        rcu_periph_clock_enable(RCU_GPIOD);
        rcu_periph_clock_enable(RCU_AF);
        rcu_periph_clock_enable(RCU_USART1);
        rcu_periph_clock_enable(RCU_USART0);
        gpio_pin_remap_config(GPIO_SWJ_SWDPENABLE_REMAP,ENABLE);
    rcu_periph_clock_enable(RCU_SPI0);
    /* SPI0_SCK(PA5), SPI0_MISO(PA6) and SPI0_MOSI(PA7) GPIO pin configuration */
    gpio_init(GPIOA, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_5 | GPIO_PIN_7);
    gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
    /* SPI0_CS(PA4) GPIO pin configuration */
    gpio_init(GPIOA, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
        //cs2
    gpio_init(GPIOC, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
    /* chip select invalid*/
    SPI_FLASH_CS_HIGH();
    /* SPI0 parameter config */
    spi_init_struct.trans_mode           = SPI_TRANSMODE_FULLDUPLEX;
    spi_init_struct.device_mode          = SPI_MASTER;
    spi_init_struct.frame_size           = SPI_FRAMESIZE_8BIT;
    spi_init_struct.clock_polarity_phase = SPI_CK_PL_LOW_PH_1EDGE;
    spi_init_struct.nss                  = SPI_NSS_SOFT;
    spi_init_struct.prescale             = SPI_PSC_8;
    spi_init_struct.endian               = SPI_ENDIAN_MSB;
    spi_init(SPI0, &spi_init_struct);
    /* enable SPI0 */
    spi_enable(SPI0);
调用的地方是读RDID
    \brief      read flash identification
    \param[in]  none
    \param[out] none
    \retval     flash identification
uint32_t spi_flash_read_id(void)
    uint32_t temp = 0, temp0 = 0, temp1 = 0, temp2 = 0;
    /* select the flash: chip select low */
    SPI_FLASH_CS_LOW();
    /* send "RDID " instruction */
    spi_flash_send_byte(0x9F);
    /* read a byte from the flash */
    temp0 = spi_flash_send_byte(DUMMY_BYTE);
    temp1 = spi_flash_send_byte(DUMMY_BYTE);
    temp2 = spi_flash_send_byte(DUMMY_BYTE);
    /* deselect the flash: chip select high */
    temp = (temp0 << 16) | (temp1 << 8) | temp2;
    return temp;
读出来的id是0 ,通过示波器看,CLK,也没有MOSI 以及MISO 均没有波形,spi flash init部分是GD32F303的demo code中来的
tpgf| | 2022-8-2 16:01 | 只看该作者
楼主用的几线制的spi总线啊
nawu| | 2022-8-2 16:09 | 只看该作者
需要接终端电阻吗
aoyi| | 2022-8-2 16:16 | 只看该作者
能监测一下这个临时变量吗
zljiu| | 2022-8-2 16:23 | 只看该作者
外边总线上没有波形吗
gwsan| | 2022-8-2 16:30 | 只看该作者
能正常进入发送函数里边吗
tfqi| | 2022-8-2 16:38 | 只看该作者
估计配置那有问题了
AnkerSong| | 2022-8-2 16:50 | 只看该作者
手边正好有gd的flash,测了一下你的代码,代码本身没问题。
注意一下flash的WP#引脚和HOLD#引脚要拉高,无论是通过上拉电阻还是gpio。
foxsbig| | 2022-8-13 13:52 | 只看该作者
逻辑分析仪抓一下
