| WALLYS wifi5 IPQ4019/IPQ4018/IPQ4028 802.11ac Wave2 2x2 2.4Ghz 2x2 5Ghz Industrial-grade
 Featuring with industrial-grade IPQ4018/IPQ4028 chipset Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module Support 4.940GHz to 5.825GHz Frequency Range; Support 2.400GHz to 2.482GHz Support 2 x 5G MMCX Connectors and 2x2.4G MMCX 20MHz/40MHz/80MHz Bandwidth Support 11ABGN/AC RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
 Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook. welcome to consult.  EMAIL:sales@wallystech.com WEB:https://www.wallystech.com/
 | Symbol | Parameter |  | CPU | IPQ4018 (Quad core ARM Cortex A7 at 710 MHz) |  | Antenna Connector | 2 x 5G MMCX connectors;2x2.4G MMCX |  | 10/100/1000Mbps Gigabit Ethernet | 2xRJ45 |  | SFP connector | 1xSFP fiber module connector (optional) |  | 3G/4G connector | 1xminipcie 3G/4G connector support with two sim card |  | USB connector | 1xUSB 3.0 connector |  | POE | 24V~48V passive POE |  | DC Jack | 24V~48V power supply |  | ROHS Compliance | YES |  | Dimension | 115mm x 105mm x 16mm |  | Nor Flash | 2MB~32MB |  | Nand Flash | 128MB |  | DDR | 256MB |
 | Operating Mode | Data Rate | Sensitivity |  | 802.11g | 6 Mbps | -96dBm |  | 54 Mbps | -78dBm |  | 802.11n HT20 | MCS0, MCS8 | -92dBm |  | MCS7, MCS15 | -73dBm |  | 802.11n HT40 | MCS0, MCS8 | -90dBm |  | MCS7, MCS15 | -70dBm |
