Clion用STlink烧录STM32HAL库项目失败
747|0
 楼主| DuDuz 发表于 2022-7-23 21:54 | 显示全部楼层 |阅读模式
前天能正常烧录程序,第二天烧录就报这个错误,球球好心人帮忙解答一下,急!报错如下:xPack OpenOCD x86_64 Open On-Chip Debugger 0.11.0+dev (2022-03-25-17:32)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
Info : The selected transport took over low-level target control. The results mi
ght differ compared to plain JTAG/SWD
Info : DEPRECATED target event trace-config; use TPIU events {pre,post}-{enable,
disable}
adapter speed: 10000 kHz
Info : clock speed 10000 kHz
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
