[PCB设计资料] wallys router//IPQ5018 802.11ax wifi 6e QCN9074/QCN9024 2X2 2.4G
1166|0
 楼主| wirelesswifi6 发表于 2022-8-29 10:31 | 显示全部楼层 |阅读模式
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW/QCA9531DR5018
wallys router//IPQ5018, 802.11ax,wifi 6e,QCN9074/QCN9024,  2X2 2.4G support 2x WiFi 6E Card support BT5.1
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;
M.2 Card Slot for QCN9074 WIFI 6E Card
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm-Atheros IPQ5018
    CPU Frequency
    Dual-core ARM 64 bit A53 @1.0 GHz processor
    System Memory
    512MB DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    4 x 1Gbps Ethernet Ports  or 1 x 1Gbps Ethernet Port & Poe
    NGFF Slot
    M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
    EMMC
    4G/8G(optional)
    USB /header
    1x USB 3.0 Port
    POE
    NA
    DC Jack
    12V power supply
    LED header
    LED for power ,Wifi strength
    Serial Port
    support
    Wireless
    On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
    2x IPEX Connectors
    BluetoothBT5.1
    Nor Flash
    8MB
    Nand Flash
    128 MB
    DDR
    512MB
    Dimension
    170mm x 120mm x 15mm
      DR9074-6E(PN02.7)
      QCN9074 802.11ax 4x4 MU-MIMO 6GHz wifi6E
      QCN9074 11ax 4x4 6G M.2
        ■ Qualcomm Atheros QCN9074
        ■ 6GHz, max 23dBm per chain, up to 4949Mbps
        ■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
        ■ 4 spatial streams (4SS)
        ■ M.2 E Key Interface
        ■ PCI Express 3.0 Interface
          Symbol
          Parameter
          Chipset
          WLAN Host Interface
          System Memory
          2Mbit serial I²C bus EEPROM
          Standard Operating Voltage
          5V
          Operating Systems
          QSDK
          Host Interface
          M.2 E Key
          Antenna Cable / Port
          4 x MMCX Connectors,4T4R
          Frequency Range
          5.925GHz-7.125GHz
          Data Rates for WALN
          Channel Spectrum Widths for WLAN
          Support 20/40/80/160MHz at 6GHz
          Modulation Techniques
          OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
          Temperature Range
          Operating: -20°C to 70°C, Storage: -40°C to 90°C
          Humidity
          Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
          Certification
          TBD
          Power Consumption
          TBD
          Reference Design
          PN02.7
          Dimensions (WxHxD)
          57mm x 63mm x 6mm
          Enhanced security operations such as physical security and surveillance analytics are required by almost all industries, including banking, retail, critical infrastructure, government, corporate, education and public transportation. Such security measures provide real-time intelligence for live detection of safety and security events and are instrumental not only in safeguarding business intelligence but also in facilitating efficient workforce management and optimizing operational decisions.
          EMAIL:sales@wallystech.com
          WEB:
          https://www.wallystech.com/
          https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
