3、完善portserial.c文件
该文件就是modbus通信中用到的串口的初始化配置文件。我这里选择usart1,波特率9600.
第一次打开这个文件,内容如下:
- void
- vMBPortSerialEnable( BOOL xRxEnable, BOOL xTxEnable )
- BOOL
- xMBPortSerialInit( UCHAR ucPORT, ULONG ulBaudRate, UCHAR ucDataBits, eMBParity eParity )
- return FALSE;
- BOOL
- xMBPortSerialPutByte( CHAR ucByte )
- return TRUE;
认真看一下函数名字,你会发现这些函数分别是:串口使能、串口初始化、发送一个字节、接收一个字节等等。
完善后代码如下:
- void
- if(xRxEnable == TRUE)
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
- else
- USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
- if(xTxEnable == TRUE)
- USART_ITConfig(USART1, USART_IT_TC, ENABLE);
- else
- USART_ITConfig(USART1, USART_IT_TC, DISABLE);
- BOOL
- USART1_Config((uint16_t)ulBaudRate);
- USART_NVIC();
- return TRUE;
- BOOL
- USART_SendData(USART1, ucByte);
- return TRUE;
- BOOL
- xMBPortSerialGetByte( CHAR * pucByte )
- *pucByte = USART_ReceiveData(USART1);
- return TRUE;
- static void prvvUARTTxReadyISR( void )
- pxMBFrameCBTransmitterEmpty( );
- static void prvvUARTRxISR( void )
- pxMBFrameCBByteReceived( );
- void USART1_IRQHandler(void)
- if(USART_GetITStatus(USART1, USART_IT_RXNE) == SET)
- prvvUARTRxISR();
- USART_ClearITPendingBit(USART1, USART_IT_RXNE);
- if(USART_GetITStatus(USART1, USART_IT_ORE) == SET)
- USART_ClearITPendingBit(USART1, USART_IT_ORE);
- prvvUARTRxISR();
- if(USART_GetITStatus(USART1, USART_IT_TC) == SET)
- prvvUARTTxReadyISR();
- USART_ClearITPendingBit(USART1, USART_IT_TC);
其中USART1_Config((uint16_t)ulBaudRate);和 USART_NVIC();是串口初始化的代码,如下:
- void USART1_Config(uint16_t buad)
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- USART_InitStructure.USART_BaudRate = buad;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No ;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- USART_Init(USART1, &USART_InitStructure);
- USART_Cmd(USART1, ENABLE);
- void USART_NVIC(void)
- NVIC_InitTypeDef NVIC_InitStructure;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
