[STM32WB] STM32WB55烧录问题
493|0
 楼主| zyj213 发表于 2022-8-31 19:13 | 显示全部楼层 |阅读模式
烧录工具 STM32CubeProg V2.9, 烧录器 ST-link V2.
板上烧录,FUS 烧录完成,显示no error, 版本1.2.0,
烧录Stack时,显示错误:**Error: The FUS version you're trying to install is older/equal to the FUS version already installed !**
请问如何处理这个问题?
以下为LOG:
11:06:18 : STM32CubeProgrammer API v2.9.0
11:06:27 : ST-LINK SN  : 55FF73064980555754491987
11:06:27 : ST-LINK FW  : V2J38S7
11:06:27 : Board       : --
11:06:27 : Voltage     : 2.90V
11:06:27 : SWD freq    : 4000 KHz
11:06:27 : Connect mode: Under Reset
11:06:27 : Reset mode  : Hardware reset
11:06:27 : Device ID   : 0x495
11:06:27 : Revision ID : Rev Y
11:06:27 : Voltage     : 2.93V
11:06:28 : SWD freq    : 4000 KHz
11:06:28 : Connect mode: Under Reset
11:06:28 : Reset mode  : Hardware reset
11:06:28 : Device ID   : 0x495
11:06:28 : Revision ID : Rev Y
11:06:28 : Debug in Low Power mode enabled.
11:06:29 : UPLOADING OPTION BYTES DATA ...
11:06:29 :   Bank          : 0x00
11:06:29 :   Address       : 0x58004020
11:06:29 :   Size          : 96 Bytes
11:06:29 :   Bank          : 0x01
11:06:29 :   Address       : 0x58004080
11:06:29 :   Size          : 8 Bytes
11:06:29 : UPLOADING ...
11:06:29 :   Size          : 1024 Bytes
11:06:29 :   Address       : 0x8000000
11:06:29 : Read progress:
11:06:29 : Data read successfully
11:06:29 : Time elapsed during the read operation is: 00:00:00.012
11:06:38 : Flash sector erase ...
11:08:38 : Error: Sector erase operation has failed at least for one of the existing specified sectors.Please verify flash memory protection.
11:08:43 : Warning: Option Byte: nSWboot0, value: 0x0, was not modified.
11:08:43 : Warning: Option Byte: nboot0, value: 0x1, was not modified.
11:08:43 : Warning: Option Byte: nboot1, value: 0x1, was not modified.
11:08:43 : Warning: Option Bytes are unchanged, Data won't be downloaded
11:08:43 : Succeeded to set nSWboot0=0 nboot1=1 nboot0=1
11:08:43 : Memory Programming ...
11:08:43 : Opening and parsing file: 0x495_FUS_Operator.bin
11:08:43 :   File          : 0x495_FUS_Operator.bin
11:08:43 :   Size          : 8 KBytes
11:08:43 :   Address       : 0x08000000
11:08:43 : Erasing memory corresponding to segment 0:
11:08:43 : Erasing internal memory sectors [0 1]
11:08:43 : Download in Progress:
11:08:44 : File download complete
11:08:44 : Time elapsed during download operation: 00:00:00.972
11:08:44 : Application is running, Please Hold on...
11:08:44 : Reconnecting...
11:08:44 : Reconnected !
11:08:45 : FUS_STATE_IDLE
11:08:45 : Read FUS state command execution finished
11:08:45 : UPLOADING ...
11:08:45 :   Size          : 4 Bytes
11:08:45 :   Address       : 0x20010010
11:08:45 : Read progress:
11:08:45 : Data read successfully
11:08:45 : Time elapsed during the read operation is: 00:00:00.008
11:08:45 :   Address       : 0x8001FFC
11:08:45 : Time elapsed during the read operation is: 00:00:00.007
11:08:54 : UPLOADING ...
11:08:54 :   Size          : 4 Bytes
11:08:54 :   Address       : 0x1FFF8070
11:08:54 : Read progress:
11:08:54 : Data read successfully
11:08:54 : Time elapsed during the read operation is: 00:00:00.008
11:08:56 : Old Firmware delete ...
11:08:56 : Warning: Option Byte: nSWboot0, value: 0x0, was not modified.
11:08:56 : Warning: Option Byte: nboot0, value: 0x1, was not modified.
11:08:56 : Warning: Option Byte: nboot1, value: 0x1, was not modified.
11:08:56 : Warning: Option Bytes are unchanged, Data won't be downloaded
11:08:56 : Succeeded to set nSWboot0=0 nboot1=1 nboot0=1
11:08:56 : Memory Programming ...
11:08:56 : Opening and parsing file: 0x495_FUS_Operator.bin
11:08:56 :   File          : 0x495_FUS_Operator.bin
11:08:56 :   Size          : 8 KBytes
11:08:56 :   Address       : 0x08000000
11:08:56 : Erasing memory corresponding to segment 0:
11:08:57 : Erasing internal memory sectors [0 1]
11:08:57 : Download in Progress:
11:08:58 : File download complete
11:08:58 : Time elapsed during download operation: 00:00:02.009
11:08:58 : Application is running, Please Hold on...
11:09:05 : Reconnecting...
11:09:06 : Reconnected !
11:09:06 : Warning: FUS_STATE_IMG_NOT_FOUND, Flash already empty !
11:09:07 : Firmware delete Success
11:09:07 : Download Stack/FUS image at address 0x80ca000 ...
11:09:07 : Memory Programming ...
11:09:07 : Opening and parsing file: stm32wb5x_BLE_Stack_full_fw.bin
11:09:07 :   File          : stm32wb5x_BLE_Stack_full_fw.bin
11:09:07 :   Size          : 170604 Bytes
11:09:07 :   Address       : 0x080CA000
11:09:07 : Erasing memory corresponding to segment 0:
11:09:08 : Erasing internal memory sectors [202 243]
11:09:09 : Download in Progress:
11:09:13 : File download complete
11:09:13 : Time elapsed during download operation: 00:00:05.949
11:09:13 : Verifying ...
11:09:13 : Read progress:
11:09:16 : Download verified successfully
11:09:16 : Firmware Upgrade process started ...
11:09:17 : Application is running, Please Hold on...
11:09:29 : Reconnecting...
11:09:29 : Reconnected !
11:09:29 : Error: The FUS version you're trying to install is older/equal to the FUS version already installed !
