[应用方案] [M051] IO Switching Example with UID Advanced Protection
776|0
 楼主| cr315 发表于 2022-9-2 15:30 | 显示全部楼层 |阅读模式
Application: Example code for determining whether IO is switched by checking a custom UID
BSP Version: M051 Series BSP CMSIS v3.01.001
Hardware: NuTiny–EVB–M051_V3.0
The Nuvoton M051 series microprocessor provides a UID (Unique Identifier). The developer can determine whether the application continues to execute by identifying the correctness of the UID and ensuring that the product is not copied. Simple UID recognition security seems to be insufficient, so it will provide an example of custom recognition complexity. Developers can perform custom operations based on the UID of the microprocessor and use the calculated UID to identify better security.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1204153512
