[应用方案] [Nano100B] Timer Trigger PDMA
620|0
 楼主| cr315 发表于 2022-9-2 15:31 | 显示全部楼层 |阅读模式
Application: Timer Trigger PDMA
BSP Version: NANO100B BSP CMSIS V3.03.001
Hardware: NANO100B-Tiny
NuMicro® NANO100B supports TIMER trigger PDMA. In NANO100B, the sample bsp\SampleCode\StdDriver\PDMA_memory shows memory to memory transfer. The sample Timer_Trigger_PDMA modifies BSP sample PDMA_memory to demonstrate TIMER0 to trigger PDMA channel 1 to do memory to memory transfer.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1223204542
