[STM32L0] 串口无法使用
914|19
 楼主| llljh 发表于 2022-9-3 16:04 | 显示全部楼层 |阅读模式
STM32L031退出STOP模式后 串口无法使用
tian111 发表于 2022-9-3 16:06 | 显示全部楼层
不进入stop模式呢
 楼主| llljh 发表于 2022-9-3 16:11 | 显示全部楼层
不进入stop模式串口正常
 楼主| llljh 发表于 2022-9-3 16:13 | 显示全部楼层
void test1(void)
    HAL_Init();
    RTC_Config();
    while(1)
        SystemClock_Config();
        init();
        printf("------- wake up --------\r\n");
        LedOn(1);
        HAL_Delay(5000);
        LedOff(1);
        HAL_Delay(5000);
        printf("\r\n------- sleep --------\r\n");
        rtc_wakeup_cfg();
        SystemPower_Config();
        HW_WakeupPinInit();
        enter_stop_mode();
void init()
    MX_GPIO_Init();
    MX_DMA_Init();
    MX_LPUART1_UART_Init();
    MX_USART2_UART_Init();
    delay_init(32);
    /* USER CODE BEGIN 2 */
    EnableUartIT();
    LedInit();
void rtc_wakeup_cfg(void)
    HAL_RTCEx_DeactivateWakeUpTimer(&RTCHandle);
    HAL_RTCEx_SetWakeUpTimer_IT(&RTCHandle, RTC_TIME,
    RTC_WAKEUPCLOCK_CK_SPRE_16BITS);
void enter_stop_mode(void)
    __HAL_RCC_PWR_CLK_ENABLE();
    HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
void HW_WakeupPinInit(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    GPIO_InitStruct.Pin = GPIO_PIN_6 | GPIO_PIN_7;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
    __HAL_RCC_GPIOA_CLK_ENABLE();
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_13 | GPIO_PIN_14;
    GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_OD;
    NVIC_SetPriority((IRQn_Type)(EXTI4_15_IRQn), 0x03);
    HAL_NVIC_EnableIRQ((IRQn_Type)(EXTI4_15_IRQn));
void SystemClock_Config(void)
    RCC_OscInitTypeDef RCC_OscInitStruct;
    RCC_ClkInitTypeDef RCC_ClkInitStruct;
    RCC_PeriphCLKInitTypeDef PeriphClkInit;
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
    RCC_OscInitStruct.HSIState = RCC_HSI_ON;
    RCC_OscInitStruct.HSICalibrationValue = 16;
    RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
    RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_4;
    RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_2;
    if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
        _Error_Handler(__FILE__, __LINE__);
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
    RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
    PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART2|RCC_PERIPHCLK_LPUART1;
    PeriphClkInit.Usart2ClockSelection = RCC_USART2CLKSOURCE_PCLK1;
    PeriphClkInit.Lpuart1ClockSelection = RCC_LPUART1CLKSOURCE_PCLK1;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
    HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
    HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
static void SystemPower_Config(void)
    HAL_PWREx_EnableUltraLowPower();
    HAL_PWREx_EnableFastWakeUp();
    __HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_MSI);
    __HAL_RCC_GPIOB_CLK_ENABLE();
    __HAL_RCC_GPIOC_CLK_ENABLE();
    __HAL_RCC_GPIOH_CLK_ENABLE();
    GPIO_InitStructure.Pin = GPIO_PIN_All;
    GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
    GPIO_InitStructure.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
    HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
    HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
    HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
    __HAL_RCC_GPIOA_CLK_DISABLE();
    __HAL_RCC_GPIOB_CLK_DISABLE();
    __HAL_RCC_GPIOC_CLK_DISABLE();
    __HAL_RCC_GPIOH_CLK_DISABLE();
static void RTC_Config(void)
  RTCHandle.Instance = RTC;
  RTCHandle.Init.HourFormat = RTC_HOURFORMAT_24;
  RTCHandle.Init.AsynchPrediv = RTC_ASYNCH_PREDIV;
  RTCHandle.Init.SynchPrediv = RTC_SYNCH_PREDIV;
  RTCHandle.Init.OutPut = RTC_OUTPUT_DISABLE;
  RTCHandle.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  RTCHandle.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  if(HAL_RTC_Init(&RTCHandle) != HAL_OK)
    Error_Handler();
void MX_GPIO_Init(void)
    GPIOA->MODER = 0xFFFFFFFF;
    GPIOB->MODER = 0xFFFFFFFF;
    GPIOC->MODER = 0xFFFFFFFF;
    GPIOH->MODER = 0xFFFFFFFF;
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_1, GPIO_PIN_RESET);
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4|GPIO_PIN_5, GPIO_PIN_SET);
    GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5;
    GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    GPIO_InitStruct.Pin = GPIO_PIN_7|GPIO_PIN_6;
    GPIO_InitStruct.Pull = GPIO_PULLDOWN;
    HAL_NVIC_SetPriority(EXTI4_15_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(EXTI4_15_IRQn);
void MX_DMA_Init(void)
  __HAL_RCC_DMA1_CLK_ENABLE();
  HAL_NVIC_SetPriority(DMA1_Channel2_3_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Channel2_3_IRQn);
void MX_LPUART1_UART_Init(void)
    hlpuart1.Instance = LPUART1;
    hlpuart1.Init.BaudRate = 115200;
    hlpuart1.Init.WordLength = UART_WORDLENGTH_8B;
    hlpuart1.Init.StopBits = UART_STOPBITS_1;
    hlpuart1.Init.Parity = UART_PARITY_NONE;
    hlpuart1.Init.Mode = UART_MODE_TX_RX;
    hlpuart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
    hlpuart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
    hlpuart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
    if (HAL_UART_Init(&hlpuart1) != HAL_OK)
void MX_USART2_UART_Init(void)
    huart2.Instance = USART2;
    huart2.Init.BaudRate = 115200;
    huart2.Init.WordLength = UART_WORDLENGTH_8B;
    huart2.Init.StopBits = UART_STOPBITS_1;
    huart2.Init.Parity = UART_PARITY_NONE;
    huart2.Init.Mode = UART_MODE_TX_RX;
    huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
    huart2.Init.OverSampling = UART_OVERSAMPLING_16;
    huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
    huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
    if (HAL_UART_Init(&huart2) != HAL_OK)
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  if(huart->Instance==LPUART1)
    __HAL_RCC_LPUART1_CLK_ENABLE();
    GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF6_LPUART1;
    hdma_lpuart1_rx.Instance = DMA1_Channel3;
    hdma_lpuart1_rx.Init.Request = DMA_REQUEST_5;
    hdma_lpuart1_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_lpuart1_rx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_lpuart1_rx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_lpuart1_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_lpuart1_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_lpuart1_rx.Init.Mode = DMA_NORMAL;
    hdma_lpuart1_rx.Init.Priority = DMA_PRIORITY_LOW;
    if (HAL_DMA_Init(&hdma_lpuart1_rx) != HAL_OK)
    __HAL_LINKDMA(huart,hdmarx,hdma_lpuart1_rx);
    HAL_NVIC_SetPriority(AES_RNG_LPUART1_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(AES_RNG_LPUART1_IRQn);
  else if(huart->Instance==USART2)
    __HAL_RCC_USART2_CLK_ENABLE();
    GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10;
    GPIO_InitStruct.Alternate = GPIO_AF4_USART2;
    HAL_NVIC_SetPriority(USART2_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(USART2_IRQn);
void HAL_UART_MspDeInit(UART_HandleTypeDef* huart)
    __HAL_RCC_LPUART1_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_2|GPIO_PIN_3);
    HAL_DMA_DeInit(huart->hdmarx);
    HAL_NVIC_DisableIRQ(AES_RNG_LPUART1_IRQn);
    __HAL_RCC_USART2_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_9|GPIO_PIN_10);
    HAL_NVIC_DisableIRQ(USART2_IRQn);
void EnableUartIT(void)//′??ú3?ê??ˉ
    __HAL_UART_ENABLE_IT(&hlpuart1, UART_IT_IDLE);
    __HAL_UART_CLEAR_IDLEFLAG(&hlpuart1);    HAL_UART_Receive_DMA(&hlpuart1,LPUart1type.LPUart1DMARecBuff,LPUART1_DMA_REC_SIZE);
    __HAL_UART_ENABLE_IT(&huart2, UART_IT_RXNE);
    HAL_UART_Receive_IT(&huart2, &Usart2Rx, 1);
更多操作
zyf部长 发表于 2022-9-3 16:15 | 显示全部楼层
恢复后好像需要重新初始化一次
 楼主| llljh 发表于 2022-9-3 16:18 | 显示全部楼层
有重新初始化的  代码补上了~
 楼主| llljh 发表于 2022-9-3 16:21 | 显示全部楼层
重新初始化就行
xxrs 发表于 2022-9-3 16:23 | 显示全部楼层
重新初始化
heweibig 发表于 2022-9-3 16:25 | 显示全部楼层
STOP模式退出后要重新初始化所有之前初始化的外设。
 楼主| llljh 发表于 2022-9-3 16:27 | 显示全部楼层
嗯,预料中的结果,多谢大家啦
极客晨星 发表于 2022-9-26 00:35 | 显示全部楼层
正常来说是需要重新配置一下,不然会有不好使的可能
地下縱情搖擺 发表于 2022-9-26 23:51 | 显示全部楼层
是的,你需要重新初始化一下
热爱童话世界 发表于 2022-9-27 00:13 | 显示全部楼层
你说的stop是进入到低功耗模式了么?
笨蛋无需搭理 发表于 2022-9-27 00:57 | 显示全部楼层
你查一下说明手册呗,进入stop模式会关掉那些外设
占得人间第一春 发表于 2022-9-27 01:19 | 显示全部楼层
可爱的白兔先生 发表于 2022-9-27 01:42 | 显示全部楼层
一般是进入到STOP会关掉一些外设,比如串口等等,然后你退出需要开启一下串口,才能正常使用
情和欲 发表于 2022-9-27 02:04 | 显示全部楼层
你进入到stop模式干啥?想降低功耗吗?
討厭和人归類 发表于 2022-9-27 02:26 | 显示全部楼层
好像可以不进入STOP模式,选择睡眠模式还是啥来着就不会关闭串口了
林间有新绿 发表于 2022-9-27 02:48 | 显示全部楼层
你重新配置一下就好了,退出STOP模式之后重新配置一下串口
风吻过你的不羁 发表于 2022-9-27 05:03 | 显示全部楼层
你重新初始化就好使了是不?我记得是这样才行
