[STM32F1]
SDIO低于2M的时钟 比较可靠
308|16
chuxh|  楼主 | 2022-9-9 21:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
FATFS   SDIO 读写SD卡,一但高于 写入SD卡就很容易失败
jiajs| | 2022-9-9 21:45 | 只看该作者
硬件原因吧
jlyuan| | 2022-9-9 21:48 | 只看该作者
单片机没那么快吧。
chuxh|  楼主 | 2022-9-9 21:49 | 只看该作者
怀疑过硬件,但是硬件不知道怎么调整.
chuxh|  楼主 | 2022-9-9 21:54 | 只看该作者
是不断加电阻来调整振铃吗?
renyaq| | 2022-9-9 21:56 | 只看该作者
不应该呀,10几M都没有问题的,你怎么弄的?没想法
ousj| | 2022-9-9 21:58 | 只看该作者
STM32时钟还有 SPI时间是不是低了
chuxh|  楼主 | 2022-9-9 22:00 | 只看该作者
开始写几K数据正常,  然后就写入失败  FSFAT 报硬件错误. 或是磁盘错误
jiahy| | 2022-9-9 22:04 | 只看该作者
你截一下sdio报告的错误类型
chuxh|  楼主 | 2022-9-9 22:06 | 只看该作者
--->f_read fileIndex=1
===>i=1 BAT Status=1 V= 4061==100!
---> f_open Pen_001.pen
!!打开太多文件。   FR_TOO_MANY_OPEN_FILES
--->OpenFilePageFunc f_open rst=18
--->CloseFilePageFunc f_close rst=9
!!无效的文件或路径。               FR_INVALID_NAME
typedef enum {
        FR_OK = 0,                                /* (0) Succeeded */
        FR_DISK_ERR,                        /* (1) A hard error occurred in the low level disk I/O layer */
        FR_INT_ERR,                                /* (2) Assertion failed */
        FR_NOT_READY,                        /* (3) The physical drive cannot work */
        FR_NO_FILE,                                /* (4) Could not find the file */
        FR_NO_PATH,                                /* (5) Could not find the path */
        FR_INVALID_NAME,                /* (6) The path name format is invalid */
        FR_DENIED,                                /* (7) Access denied due to prohibited access or directory full */
        FR_EXIST,                                /* (8) Access denied due to prohibited access */
        FR_INVALID_OBJECT,                /* (9) The file/directory object is invalid */
        FR_WRITE_PROTECTED,                /* (10) The physical drive is write protected */
        FR_INVALID_DRIVE,                /* (11) The logical drive number is invalid */
        FR_NOT_ENABLED,                        /* (12) The volume has no work area */
        FR_NO_FILESYSTEM,                /* (13) There is no valid FAT volume */
        FR_MKFS_ABORTED,                /* (14) The f_mkfs() aborted due to any parameter error */
        FR_TIMEOUT,                                /* (15) Could not get a grant to access the volume within defined period */
        FR_LOCKED,                                /* (16) The operation is rejected according to the file sharing policy */
        FR_NOT_ENOUGH_CORE,                /* (17) LFN working buffer could not be allocated */
        FR_TOO_MANY_OPEN_FILES,        /* (18) Number of open files > _FS_SHARE */
        FR_INVALID_PARAMETER        /* (19) Given parameter is invalid */
} FRESULT;
llljh| | 2022-9-9 22:08 | 只看该作者
F1能到这么快?应该时钟不行吧
chuxh|  楼主 | 2022-9-9 22:10 | 只看该作者
我发现 是有时 硬件出错,  我只好出错后 重新关掉此文件 再打开
yinxiangh| | 2022-9-9 22:12 | 只看该作者
是否地线处理的不好有干扰呀
chuxh|  楼主 | 2022-9-9 22:14 | 只看该作者
我这个板 就只有通讯,  SDIO一路 SPI 二路 串口二路
SDIO是给SD卡, SPI 有一路字库 和 WIFI  二串口 波特率115200
不好排查啊
chuxh|  楼主 | 2022-9-9 22:16 | 只看该作者
我现在写入错误, 我就重新打开此文件,   可是这样就丢数据了 .  频率特别高.  很是郁闷
stly| | 2022-9-9 22:20 | 只看该作者
先把波特率降下来试试
chuxh|  楼主 | 2022-9-9 22:22 | 只看该作者
另外 还发现一个问题   f_lseek()     有时花很长的时间 才执行完  要40ms之久
