| 用的是ST的固件库编程,部分代码如下: FLASH_SetProgrammingTime(FLASH_PROGRAMTIME_STANDARD);
 /* Unlock Data memory */
 FLASH_Unlock(FLASH_MEMTYPE_DATA);
 /* Fill the buffer in RAM */
 for (i = 0; i < FLASH_BLOCK_SIZE; i++) GBuffer = new_val2;
 /* Program the block 0*/
 block = 0; /* block 0 is first block of Data memory: address is 0x4000 */
 FLASH_ProgramBlock(block, FLASH_MEMTYPE_DATA, FLASH_PROGRAMMODE_STANDARD, GBuffer);
 FLASH_WaitForLastOperation(FLASH_MEMTYPE_DATA);
 编译没问题,点运行不报错,就是程序一直处于运行状态,点暂停的时候会出现遇到无效参数的提示,程序死机,重新编译运行,用单步发现程序在FLASH_ProgramBlock(block, FLASH_MEMTYPE_DATA, FLASH_PROGRAMMODE_STANDARD, GBuffer);
 这里有问题,报错Stop...Error:  swim prog error [42004]: memory write error
 不知道是什么问题
