[全新] ZCC5160 同步降压 60V 3A V2.0
344|0
 楼主| SWdianzi 发表于 2022-9-15 16:13 | 显示全部楼层 |阅读模式
Features
20-µA Quiescent current in regulation
Input voltage range: 4V-60V
Output voltage range: 1V-VIN
Integrated upper and lower power MOSFET
maximum current: 5A
Adjustable frequency range: 200KHz~2MHz
Automatic switching of CCM/DCM/PFM mode
Adjustable soft-start time and Output voltage
tracking capability
Automatically switched bypass linear power
supply
Provides ultra-low input and output dropout
voltage close to 100% duty cycle
Internal Compensation
Power-good flag
Dynamic Frequency Stretch Technology
Support large capacitive load start-up
Protection function: UVLO/OCP/SCP/OTP/OVP
Operating junction temperature range: -40℃ to
+125℃
All pins have ±2000V (HBM) ESD protection
ETSSOP 16-Pin Exposed Pad Package
Applications
Industrial power supply
Wide voltage input range power supply
Low ripple low noise power supply
Automotive electronic power supply
Figure. 1 Typical Application Circuit
Description
ZCC5160 is a step-down DC/DC regulator with an
internal switch, featuring SKIP control mode, which
combines low quiescent current with high switching
frequency to achieve high-efficiency regulation over a
wide range of load currents. SKIP mode uses a short
"burst" cycle to switch the inductor current through
the internal power MOSFET, followed by a sleep
cycle in which the power switch is turned off and the
load current is provided by the output capacitor. At
light loads, burst cycles are a small fraction of the
total cycle time, minimizing average supply current
and greatly improving efficiency at light loads.
ZCC5160 has a wide input voltage range of 4V-60V,
thus minimizing the need for external surge
suppression components. Making it the best choice
for wide input power range industrial and high cell
count battery pack applications. ZCC5160 is ideal for
use in the 48V automotive power bus range.
ZCC5160 features low-value 100mΩ high-side and
80mΩ low-side MOSFET that provide at least 3A
output current capability with excellent load and line
transient response.
Additional features include: soft-start, thermal
shutdown, UVLO undervoltage lockout, gate driver
undervoltage lockout, maximum duty cycle limit timer,
and current limit shutdown timer. It also integrates
output short-circuit protection, providing HICCUP
mode when the FB voltage is low to avoid
overheating during short-circuit.
