GD32E230串口0使用PB6、PB7的问题
2321|2
 楼主| ya1234 发表于 2022-9-29 11:33 | 显示全部楼层 |阅读模式
GD32E230的datasheet中可以看到PB和PB7是可以复用到USART0的,然后使用官方的例程,将官方例程默认引进从PA9、PA10改成PB6、PB7,结果串口就不打印了。用PA9、PA10却可以。
请教一下有没有人知道PB6、PB7怎么当串口0使用?
以下是官方例程,我将引脚宏定义改成PB6和PB7:
/* definition for COM, connected to USART0 */
#define EVAL_COM                         USART0
#define EVAL_COM_CLK                     RCU_USART0
#define EVAL_COM_TX_PIN                  GPIO_PIN_6
#define EVAL_COM_RX_PIN                  GPIO_PIN_7
#define EVAL_COM_GPIO_PORT               GPIOB
#define EVAL_COM_GPIO_CLK                RCU_GPIOB
#define EVAL_COM_AF                      GPIO_AF_1
    \brief      configure COM port
    \param[in]  com: COM on the board
      \arg        EVAL_COM: COM on the board
    \param[out] none
    \retval     none
void gd_eval_com_init(uint32_t com)
    uint32_t COM_ID;
    COM_ID = 0U;
    /* enable COM GPIO clock */
    rcu_periph_clock_enable(EVAL_COM_GPIO_CLK);
    /* enable USART clock */
    rcu_periph_clock_enable(COM_CLK[COM_ID]);
    /* connect port to USARTx_Tx */
    gpio_af_set(EVAL_COM_GPIO_PORT, EVAL_COM_AF, COM_TX_PIN[COM_ID]);
    /* connect port to USARTx_Rx */
    gpio_af_set(EVAL_COM_GPIO_PORT, EVAL_COM_AF, COM_RX_PIN[COM_ID]);
    /* configure USART Tx as alternate function push-pull */
    gpio_mode_set(EVAL_COM_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, COM_TX_PIN[COM_ID]);
    gpio_output_options_set(EVAL_COM_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, COM_TX_PIN[COM_ID]);
    /* configure USART Rx as alternate function push-pull */
    gpio_mode_set(EVAL_COM_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, COM_RX_PIN[COM_ID]);
    gpio_output_options_set(EVAL_COM_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, COM_RX_PIN[COM_ID]);
    /* USART configure */
    usart_deinit(com);
    usart_baudrate_set(com, 115200U);
    usart_receive_config(com, USART_RECEIVE_ENABLE);
    usart_transmit_config(com, USART_TRANSMIT_ENABLE);
    usart_enable(com);
 楼主| ya1234 发表于 2022-9-29 16:02 | 显示全部楼层
问题解决了,原来是PB6、PB7是复用到AF_0
tail066 发表于 2022-10-8 21:06 | 显示全部楼层
复用的问题么?
