[PIC®/AVR®/dsPIC®产品]
PIC16F1508闪存程序存储器的读写问题
458|15
juventus9554|  楼主 | 2022-10-9 20:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
选用了PIC1508芯片,因该芯片没有EEPROM,所以用闪存程序存储器作为数据存储,可调试了两天没成功
zhenykun| | 2022-10-9 20:23 | 只看该作者
能读能写,可断电后再读,就没有了原保存的数据,读和擦除功能都正常
chuxh| | 2022-10-9 20:25 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
juventus9554|  楼主 | 2022-10-9 20:27 | 只看该作者
WRITE
                CALL                            ERASURE_A                                ;先擦除再写入
                BCF                             INTCON,GIE                                ; Disable ints so required sequences will execute properly
                BANKSEL                      PMADRH                                        ; Bank 3
                MOVLW                        0X0B                                        ; Load initial address
                MOVWF                        PMADRH
                MOVLW                        0X00
                MOVWF                        PMADRL
                MOVLW                        0X60                                        ; Load initial data address
                MOVWF                        FSR0L
                MOVLW                        0X00                                        ; Load initial data address
                MOVWF                        FSR0H
                BCF                              PMCON1,CFGS                                ; Not configuration space
                BSF                              PMCON1,WREN                                ; Enable writes
                BSF                              PMCON1,LWLO                                ; Only Load Write Latches
WRITE_LOOP
                MOVIW                        FSR0++                                        ; Load first data byte into lower
                MOVWF                        PMDATL
                MOVIW                        FSR0++                                        ; Load second data byte into upper
                MOVWF                        PMDATH
                MOVF                          PMADRL,W                                ; Check if lower bits of address are '00000'
                XORLW                        0x17                                        ; Check if we're on the last of 32 addresses
                ANDLW                        0x17
                BTFSC                         STATUS,Z                                ; Exit if last of 32 words,
                GOTO                          START_WRITE
                MOVLW                       55h                                        ; Start of required write sequence:
                MOVWF                       PMCON2                                        ; Write 55h
                MOVLW                       0AAh
                MOVWF                       PMCON2                                        ; Write AAh
                BSF                             PMCON1,WR                                ; Set WR bit to begin write
                NOP        ; NOP instructions are forced as processor loads program memory write latches
                NOP
                INCF                           PMADRL                                        ; Still loading latches Increment address
                GOTO                          WRITE_LOOP                                ; Write next latches
START_WRITE
                BCF                             PMCON1,LWLO                                ; No more loading latches - Actually start Flash program memory write
                MOVLW                        0AAh
                NOP
                NOP
                BCF                              PMCON1,WREN                                ; Disable writes
                BANKSEL                      W_TEMP
                CALL                            DELAY_RC
                BSF                             INTCON,GIE                                ; Enable interrupts
                RETURN
heweibig| | 2022-10-9 20:29 | 只看该作者
用MCC生成代码试试看, 还是C的..易读好调试...
huangchui| | 2022-10-9 20:33 | 只看该作者
汇编,我去,不懂啊。
chuxh| | 2022-10-9 20:38 | 只看该作者
汇编看不懂啊,是不是每次上电都运行了擦除程序
juventus9554|  楼主 | 2022-10-9 20:40 | 只看该作者
现在还是感觉C语言是最强大的语言。
dengdc| | 2022-10-9 20:43 | 只看该作者
有什么具体的问题吗
morrisk| | 2022-10-9 20:46 | 只看该作者
汇编看不懂啊
dengdc| | 2022-10-9 20:50 | 只看该作者
用MCC生成代码试试
yufe| | 2022-10-9 20:52 | 只看该作者
汇编代码很头疼啊
Undshing| | 2022-10-10 20:47 | 只看该作者
我去,汇编看不懂
