九齐NY8BE62D数码管02
535|0
 楼主| 34af9uc 发表于 2022-10-16 00:42 | 显示全部楼层 |阅读模式
#include <ny8.h>
//             NY8BE62D_S16
//         _______   _______
//        |1 vdd  \_/ vss 16|
//        |2 pa6      pa4 15|-scl
//        |3 pa7      pa3 14|
//        |4 pa5      pa2 13|-sda
//        |5 pb3      pa1 12|
//  led_4-|6 pb2      pa0 11|-led_1
//  led_5-|7 pb1      pb5 10|-led_2
//  led_6-|8_pb0______pb4__9|-led_3
//                 LCD CS3631AW-4-D
//                  @1@2@3@4@5@6
//     ___A1___      ___A2___      ___A3___
//    F1      B1    F2      B2    F3      B3
//    |___G1___|    |___G2___|    |___G3___|
//    E1      C1 DP E2      C2 DP E3      C3 DP
//    |___D1___|.   |___D2___|.   |___D3___|.
//  1  1  4  5  1  2  3  1    2  2  5  2  2  3  4  3    5  3  4  6  6  4  5  4
//  2  3  1  1  4  1  1  6    3  4  2  6  5  2  2  6    4  5  5  1  3  3  3  6
// A1 B1 C1 D1 E1 F1 G1 DP   A2 B2 C2 D2 E2 F2 G2 DP   A3 B3 C3 D3 E3 F3 G3 DP
__sbit led_1                =PORTA:0;
__sbit led_2                =PORTB:5;
__sbit led_3                =PORTB:4;
__sbit led_4                =PORTB:2;
__sbit led_5                =PORTB:1;
__sbit led_6                =PORTB:0;
/**************************************************/                //0输出1输入
#define                led_1_h                IOSTA&=~(1<<0);led_1=1
#define                led_2_h                IOSTB&=~(1<<5);led_2=1
#define                led_3_h                IOSTB&=~(1<<4);led_3=1
#define                led_4_h                IOSTB&=~(1<<2);led_4=1
#define                led_5_h                IOSTB&=~(1<<1);led_5=1
#define                led_6_h                IOSTB&=~(1<<0);led_6=1
#define                led_1_l                IOSTA&=~(1<<0);led_1=0
#define                led_2_l                IOSTB&=~(1<<5);led_2=0
#define                led_3_l                IOSTB&=~(1<<4);led_3=0
#define                led_4_l                IOSTB&=~(1<<2);led_4=0
#define                led_5_l                IOSTB&=~(1<<1);led_5=0
#define                led_6_l                IOSTB&=~(1<<0);led_6=0
#define                led_1_g                IOSTA|=1<<0
#define                led_2_g                IOSTB|=1<<5
#define                led_3_g                IOSTB|=1<<4
#define                led_4_g                IOSTB|=1<<2
#define                led_5_g                IOSTB|=1<<1
#define                led_6_g                IOSTB|=1<<0
void                yanshi(unsigned int x);
void main(void)
led_1_g;
led_2_g;
led_3_g;
led_4_g;
led_5_g;
led_6_g;
while(1)
led_1_l;
led_2_h;
yanshi(200);
led_1_g;
led_2_g;
yanshi(200);
unsigned int y,z;
for(y=x;y>0;y--)
        for(z=1000;z>0;z--){}
main (2).zip
898 Bytes, 下载次数: 6
319
