[放大器-信号链] 不同应用的传感器类型
2801|1
 楼主| jeff-wang 发表于 2012-4-14 10:56 | 显示全部楼层 |阅读模式
Physical Property Measured
SENSOR
Active/Passive
Output
Temperature
Thermocouple
Passive
Voltage
RTD
Active
Resistance=> Current
Thermistor
Active
Silicon
Active
Voltage/Current
Pressure/Force
Strain Gage: Resistive
Active
Stain Gage: Capacitive
Active
Capacitance=>Voltage
Piezoelectric
Passive
Voltage
Flow
Magnetic Inductive
Active
Voltage
Coriolis
Active
Voltage
Acceleration
Accelerometer
Active
Capacitance=> Voltage
Position
LVDT
Active
AC Voltage
Optical
Photodiode
Passive
Current
 楼主| jeff-wang 发表于 2012-4-14 10:57 | 显示全部楼层
Type
Example
Sample TI Solution
Attributes
Resistive
RTD/Thermistor, Strain gage (Pressure sensor)
PGA309,
ADS1232, ADS1248,ADS1232
Zero-drift, Low Voffset, Complete single chip conditioning solution
Capacitive
Humidity sensor, Level sensor
*PGA450
Sync demodulation Programmable Cal routine
Magnetic/Inductive
Coriolis
Flowmeter, Electromagnetic Flowmeter, Proximity sensor
ADS1274, ADS1259,ADS7786
Differential signal path , High sampling speed, Multiple input channels
Current
Photodetector,
Chemical sensors
OPA129, OPA320,OPT101
ADS1259
Low input bias current , Low temp-coefficient
Thermocouple
J,K,B,N,R,S,E
ADS1248,ADS1118
Low Voffset, Low drift, High Vcm, Cold junction compensation, Low noise at sub100Hz
