双通道Type-C/DP1.4到HDMI2.0转换器【LT8711UXD】
1122|0
 楼主| JLKJ18338421851 发表于 2022-10-29 15:04 | 显示全部楼层 |阅读模式
1. 描述
LT8711UXD是一个高性能的双通道Type-C/DP1.4到HDMI2.0转换器,设计用于连接USB Type-C源或DP1.4源到HDMI2.0接收器。LT8711UXD集成了符合DP1.4标准的接收机和符合HDMI2.0标准的发射机。此外,还包括两个CC控制器,用于CC通信,实现DP Alt模式和功率传递功能,一个用于上游Type-C端口,另一个用于下游端口。
DP接收机支持每通道最大8.1Gbps的数据速率,采用HDCP 1.3/2.2/2.3内容保护方案,并嵌入密钥,实现数字音视频内容的安全传输。
HDMI接口包括4个TMDS时钟/数据对、DDC和HPD信号。HDMI发射器能够支持高达6Gpbs的数据速率,足以处理超高清4k 60Hz格式的视频分辨率。HDMI发射器包含HDCP引擎,支持HDCP1.4/2.2/2.3。由于包含了HDCP, LT8711UXD允许安全传输受保护的内容。内置密钥,提供最高级别的HDCP密钥安全性。
该设备能够自动操作,这是由一个集成的微处理器,使用嵌入式SPI闪存固件存储。系统控制也可以通过使用专用的配置I2C从接口来实现。
2. 特性
•USB c型
•DP1.4接收机
•HDMI2.0发射机
•杂项
3.应用程序
•停靠站
•电子狗
1. Description
The LT8711UXD is a high performance two lane Type-C/DP1.4 to HDMI2.0 converter, designed to connect a USB Type-C source or a DP1.4 source to an HDMI2.0 sink. The LT8711UXD integrates a DP1.4 compliant receiver, and an HDMI2.0 compliant transmitter. Also, two CC controllers are included for CC communication to implement DP Alt Mode and power delivery function, one for upstream Type-C port and another for downstream port.
The DP receiver supports maximum 8.1Gbps data rate per lane, and incorporates HDCP 1.3/2.2/2.3 content protection scheme with embedded key for secure transmission of digital audio-video content.
The HDMI interface includes 4 TMDS clock/data pairs, DDC, and HPD signal. The HDMI transmitter is capable of supporting up to 6Gpbs data rate, quite adequate for handling video resolutions up to UHD 4k 60Hz formats. The HDMI transmitter incorporates HDCP engines which support both HDCP1.4/2.2/2.3. With the inclusion of HDCP, the LT8711UXD allows secure transmission of protected content. Embedded key is available that provides the highest level of HDCP key security.
The device is capable of automatic operation which is enabled by an integrated microprocessor that uses an embedded SPI flash for firmware storage. System control is also available through the use of a dedicated configuration I2C slave interface.
2. Features
• USB Type-C
• DP1.4 Receiver
• HDMI2.0 Transmitter
• Miscellaneous
3. Applications
• Docking Station
• Dongle
九黎科技是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!
