求助,GD32470V_START UART无法正常运行
1847|0
 楼主| startupgd32f3x 发表于 2022-11-5 14:05 | 显示全部楼层 |阅读模式
GD32470V_START(GD32F470VKT6) UART无法正常运行,逻辑分析仪测试针脚无变化(一直高电平)。
所有函数都使用 GD32470V_START_Demo_Suites 的例子。感谢所有提供帮助的同学。gd_eval_com_init 来自官方教程.
int main(void)
    /* configure systick */
    systick_config();
    /* configure EVAL_COM0 */
    gd_eval_com_init(EVAL_COM0);
    /* enable the LEDs GPIO clock */
    rcu_periph_clock_enable(RCU_GPIOC);
    /* configure LED2 GPIO port */
    gpio_mode_set(GPIOC, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_6);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
    while(1) {
        usart_data_transmit(EVAL_COM0, 'O');
        while(RESET == usart_flag_get(EVAL_COM0, USART_FLAG_TBE));
        usart_data_transmit(EVAL_COM0, 'K');
        /* wait for completion of USART transmission */
        while(RESET == usart_flag_get(EVAL_COM0 ,USART_FLAG_TC)){
        /* turn on LED2 */
        gpio_bit_set(GPIOC, GPIO_PIN_6);
        //gpio_bit_set(GPIOA, GPIO_PIN_9);
        delay_1ms(100);
        gpio_bit_reset(GPIOC, GPIO_PIN_6);
        //gpio_bit_reset(GPIOA, GPIO_PIN_9);
        delay_1ms(100);
