IPQ4019 is a highly integrated system on chip (SOC), designed for high-performance, low-power and low-cost 2 × 2. 802.11ac dual band concurrent access point application The SoC focuses on the quad core arm Cortex A7 processor, two dual band parallel 802.11ac wave-2 wifi subsystems, and a 5-port Gigabit Ethernet layer 2/3/4 multilayer switch that supports line rate networks. The IPQ4019 SOC integrates an ARM Cortex-A7 processor with the advanced 802.11ac Wi-Fi (Wave 2) radio to create a highly integrated solution which supports line rate communications over a single 5G link or up to four 10G links through 4x GigE slots. The IPQ4019 SoC is specifically designed for next generation wireless applications including home gateways, enterprise access points and hotspots. IPQ4029 is the first single chip Wi Fi system on chip (SoC) in the industry that introduces Wave-2 802.11ac into various home and enterprise network products. The highly integrated single chip design combines dual band 11ac, advanced Wi Fi functions and network processing to provide various configurations to achieve high-performance, low-power and cost-effective network infrastructure products. The IPQ4029 SoC includes a highly integrated 802.11ac radio, 2x2 MIMO MU-MIMO support, high efficiency antenna tuner, integrated antenna switch and antenna diversity support. It offers a wide range of product solutions ranging from Modules to Routers & Switches to Gateways & Access Points (APs). Featuring with industrial-grade IPQ4019/IPQ4029 chipset, the Wallys Routerboard DR40X9 offers a high level of performance and reliability. Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module, this router supports 4.940GHz to 5.825GHz Frequency Range, which can support 2.400GHz to 2.482GHz bandwidth, as well as 2 x 5G MMCX Connectors and 2x2.4G MMCX Connectors that can support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidths. It also has 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth Support so that it can provide an excellent network speed for y**ices. Plus, it has 11ABGN/AC Support so that you can enjoy high quality video streaming and fast data transfer between devices connected to this router. In addition, its RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals Wallys Communications (Suzhou) Co., Ltd. is a leading Chinese company specializing in the research and development and production of wireless communication products, such as Routerboard, Network Card, Industrial Wireless AP, Antenna etc. We are committed to providing customers with OEM/ODM/JDM services for products. We have a proven track record working with RF and embedded communications, network protocol, firmware, openwrt, linux system development, analog and digital circuit design, network processors and power supplies. The company's seasoned R&D engineer team is ready to help explore your project with RF and embedded communications, network protocol, firmware development or any other field related to information technology. https://www.wallystech.com/
