[WIFI模块] MT7915+MT7975/Wi-Fi 6 mini PCIe network card DR7915/Wallys
2113|0
 楼主| lilywallys 发表于 2022-11-9 11:45 | 显示全部楼层 |阅读模式
MT7915+MT7975/Wi-Fi 6mini PCIe network card DR7915/Wallys
About MT7915 and MT7975
MediaTek presented itscombined MT7915 wifi 6 and Bluetooth 5 chipset at ces 2020,which designed for high-performance ap routers, Repeaters and mesh network devices. The MT7915 series of chipsets (MT7915a/d) is available for domestic, commercial or business applications and is already available for product development, and the first equipment is expected to be available in the first quarter of 2020.
The MediaTekMT7915 is the first combined solution of a single chip Wi-Fi 6 wave 1 + and Bluetooth 5 in the world. The chip incorporates a dedicated rf receiver and "zero wait DFS channel monitoring" (an industry initiative), allowing faster, more reliable and easy to use connections.
Patented features include the MediaTek development division's ESR technology, greater optimization of wireless network efficiency and capacity, and improved internal FEM, which can increase efficiency by 60%. It provides the bestUL coverage and better peak performance than its competitors.
Some of the Wi-Fi 6 Wave 1 + functions are optional and not supported by competitors, but the MediaTek MT7915 has marked all these functions, such as 1024QAM, UL/DL MU-MIMO user#, spatial reuse and long-range DCM.
The MT7915 integrates a dual-band architecture that provides multi-gigabit Wi-Fi speeds with options of 4x4 (MT7915A) or 2x2 (MT7915D) antenna.
The section continued to lead the deployment of the Wi-Fi Alliance EasyMeshTM certified products. The EasyMesh standard ensures interoperability of products and provides a unique and manageable Wi-Fi network that can be expanded to meet deployment needs.
Searching for a network card for your project
If you're looking for an IEEE 802.11ax compliant Wi-Fi solution, look no further than the wallys DR 7915,equipped with MT7915+MT7975 chipset, which offers two-times the throughput (up to 1.8Gbps) and up to 23dBm of output power on 2.4GHz, and up to 20dBm on 5GHz! In addition, it's backward compatible with 802.11ax/ac/a/b/g/n standards, so you can use your existing equipment and save money by skipping the upgrade.
The MT7915+MT7975 chipset supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC), IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards. It also supports Dynamic Frequency Selection (DFS) — meaning you can pick the best frequency for your environment by adjusting automatically over time.
In addition to its impressive performance chops, this chipset is RoHS compliant ensure a high level protection of human health and the environment from risks
Application for the Network card DR7915
DR 7915 is a high performance wireless module based on MT7915 + MT7975 Chipset, designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment infactories, warehouses.
Wallys Communications (Suzhou ) Co., LTD is mainly engaged in the research and development and production of wireless communication products,such as Routerboard,Network Card,Industrial Wireless AP,Antenna etc.OEM/ODM/JDM services for customers supported.
With our experienced R&D engineer team,which with a demonstratedhistory of working in the wireless industry,you can explore the project with RF and embedded communications,network protocol,firmware,openwrt,linux system,development,analog and Digital Circuit Design,Network Processors,Power supplies,PCB design and layout with us.
Welcome to email us for more information.
Email:sales1@wallystech.com
https://www.wallystech.com/
