[研电赛技术支持] GD32F305VCT6,CAN通信问题
1803|8
 楼主| zyminer 发表于 2022-11-10 15:52 | 显示全部楼层 |阅读模式
再调试GD32F305的CAN通信时,配置好后用CAN分析仪识别不了波特率是咋回事,程序是按官方例程来的呀
    CAN相关初始化程序:
void Can1_Init(void)
      can_parameter_struct  can_parameter;
    can_filter_parameter_struct  can_filter_parameter;
    /* enable CAN0 clock */
    rcu_periph_clock_enable(RCU_CAN0);
    rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_AF);
    /* configure CAN0 GPIO */
    gpio_init(GPIOB,GPIO_MODE_IPU,GPIO_OSPEED_50MHZ,GPIO_PIN_8);
    gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_9);
    gpio_pin_remap_config(GPIO_CAN0_FULL_REMAP,ENABLE);
    can_struct_para_init(CAN_INIT_STRUCT,&can_parameter);
    can_struct_para_init(CAN_FILTER_STRUCT,&can_filter_parameter);
    can_deinit(CAN0);
    /* initialize CAN parameters */
    can_parameter.time_triggered = DISABLE;
    can_parameter.auto_bus_off_recovery = DISABLE;
    can_parameter.auto_wake_up = DISABLE;
    can_parameter.no_auto_retrans = DISABLE;
    can_parameter.rec_fifo_overwrite = DISABLE;
    can_parameter.trans_fifo_order = DISABLE;
    can_parameter.working_mode = mode;
    can_parameter.resync_jump_width = CAN_BT_SJW_1TQ;
    can_parameter.time_segment_1 = CAN_BT_BS1_5TQ;
    can_parameter.time_segment_2 = CAN_BT_BS2_4TQ;
    can_parameter.prescaler = 12;
    /* initialize CAN */
    can_init(CAN0, &can_parameter);
    /* initialize filter */
    can_filter_parameter.filter_number = 0;
    can_filter_parameter.filter_mode = CAN_FILTERMODE_MASK;
    can_filter_parameter.filter_bits = CAN_FILTERBITS_32BIT;
    can_filter_parameter.filter_list_high = 0x0000;
    can_filter_parameter.filter_list_low =  0x0000;
    can_filter_parameter.filter_mask_high = 0x0000;
    can_filter_parameter.filter_mask_low = 0x0000;
    can_filter_parameter.filter_fifo_number = CAN_FIFO0;
    can_filter_parameter.filter_enable = ENABLE;
    can_filter_init(&can_filter_parameter);
    nvic_irq_enable(CAN0_RX0_IRQn,0,1);
    /* enable can receive FIFO0 not empty interrupt */
    can_interrupt_enable(CAN0, CAN_INT_RFNE0);
void CAN0_RX0_IRQHandler(void)
    /* check the receive message */
    can_message_receive(CAN0, CAN_FIFO0, &g_receive_message1);
    CAN_Receive_Flag=1;
以上就是初始化程序,连接CAN分析仪识别不了波特率不知道是咋回事。
weifeng90 发表于 2022-11-11 18:36 来自手机 | 显示全部楼层
你用的CAN分析仪支持自动识别波特率嘛?
chenqianqian 发表于 2022-11-19 11:25 来自手机 | 显示全部楼层
CAN分析仪带自动识别波特率功能不?
tpgf 发表于 2022-12-3 16:56 | 显示全部楼层
是不是晶振有误差导致波形的波特率不对啊
nawu 发表于 2022-12-3 17:07 | 显示全部楼层
CAN分析仪也不可能识别所有的波特率 会有偏差
aoyi 发表于 2022-12-4 11:14 | 显示全部楼层
可以使用万能的示波器 而且有可能是因为发送的完全可能不对
zljiu 发表于 2022-12-4 11:25 | 显示全部楼层
即便can分析仪可以自动识别波特率 也是有错误率的
gwsan 发表于 2022-12-4 11:33 | 显示全部楼层
首先确认自己发送的符合can的通讯协议啊  否则得到的数据就是错误的
tfqi 发表于 2022-12-4 11:47 | 显示全部楼层
can分析仪不是万能的  可以使用示波器卡一下波形 看发送的数据是否符合要求
