[菜农助学交流] 第五批 之二 按键外部中断
3420|0
 楼主| cnjxlxp 发表于 2012-4-15 22:21 | 显示全部楼层 |阅读模式
#include <stdio.h>
#include "NUC1xx.h"
#include "DrvGPIO.h"
#include "DrvUART.h"
#include "DrvSYS.h"
int32_t i32BitValue;
void delay_ms(void)//delay form xiaobing's source code //20ms
    uint32_t i,j;
for(i=20;i>0;i--)
    for(j=2395;j>0;j--);
void EINT0Callback(void) //intp0 service routine  //detect key by interrupt
DrvGPIO_DisableEINT0 ();//disable intp0
delay_ms();    //chattering ignore
if (DrvGPIO_GetBit (E_GPB, 14) == 0)
  GPIOA->DOUT ^= 0x8; //LED2 turns on and off
  printf("key2 is pressd.\n");
DrvGPIO_EnableEINT0 (E_IO_FALLING, E_MODE_EDGE, EINT0Callback); //enable intp0 again
//uart set//n,8,1,9600
void uart_init(void)
  STR_UART_T param;
  DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC, 0);//UART clock is ex 12M
  //SYSCLK->CLKSEL1.UART_S = 0;
  //UART clock 00 =ex 12MHz  01 = PLL 1x =inner 22MHz
  DrvGPIO_InitFunction(E_FUNC_UART0); //GPIO use as uart
  param.u32BaudRate        = 9600;
  param.u8cDataBits        = DRVUART_DATABITS_8;
  param.u8cStopBits        = DRVUART_STOPBITS_1;
  param.u8cParity          = DRVUART_PARITY_NONE;
  param.u8cRxTriggerLevel  = DRVUART_FIFO_1BYTES;
  param.u8TimeOut          = 0;  //         FIFO time out
  DrvUART_Open(UART_PORT0, &param);
// DrvUART_ClearIntFlag(UART_PORT0, DRVUART_RDAINT);
  //DrvUART_EnableInt(UART_PORT0,DRVUART_RDAINT,UART_INT_HANDLE);
void Sys_Init()
UNLOCKREG();
    SYSCLK->PWRCON.XTL12M_EN = 1;//12M
//DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1);
    DrvSYS_Delay(5000);
//while (DrvSYS_GetChipClockSourceStatus(E_SYS_XTL12M) != 1);
//SYSCLK->CLKSTATUS.XTL12M_STB
LOCKREG();
uart_init();
//DrvGPIO_Open(E_GPB, 10, E_IO_OUTPUT);//GPB10 output
    //DrvGPIO_ClrBit(E_GPB, 10);//if not clear GPB10, the buzzer will on. the default output is 0xffff;
DrvGPIO_Open(E_GPB,14, E_IO_INPUT); //GPB14 15 INPUT
DrvGPIO_Open(E_GPB,15, E_IO_INPUT); //
DrvGPIO_Open(E_GPA,2, E_IO_OUTPUT); //GPA2 output, LED1
DrvGPIO_Open(E_GPA,3, E_IO_OUTPUT); //GPA3 output, LED2
int main (void)
Sys_Init();
    while(1)
  //i32BitValue = DrvGPIO_GetBit (E_GPB, 15);
  if (DrvGPIO_GetBit (E_GPB, 15) == 1)   //detect key by polling
    //printf("key2 is not pressd.\n");
  else
    delay_ms();//chattering ignore
    if (DrvGPIO_GetBit (E_GPB, 15) == 0)
     //delay_ms();
     while(DrvGPIO_GetBit (E_GPB, 15) == 0);
     printf("KEY1 is pressd.\n");
