- #include <stdio.h>
- #include "NUC1xx.h"
- #include "Driver\DrvGPIO.h"
- #include "Driver\DrvSYS.h"
- #include "Driver\DrvUART.h"
- #include "Driver\DrvADC.h"
- #include "Driver\DrvPWM.h"
- #define Run_Led 2 //2----LED1 3----LED2 4----LED3 5----LED4
- void Init_System(void)
- UNLOCKREG(x);
- DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1);
- DrvSYS_Delay(5000);
- LOCKREG(x);
- void delay_ms(uint32_t count)
- uint32_t i,j;
- for(i=count;i>0;i--)
- for(j=2395;j>0;j--);
- void Init_Uart(void)
- STR_UART_T param;
- DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC,0);
- DrvGPIO_InitFunction(E_FUNC_UART0);
- param.u32BaudRate = 9600;
- param.u8cDataBits = DRVUART_DATABITS_8;
- param.u8cStopBits = DRVUART_STOPBITS_1;
- param.u8cParity = DRVUART_PARITY_NONE;
- param.u8cRxTriggerLevel = DRVUART_FIFO_1BYTES;
- param.u8TimeOut = 0;
- DrvUART_Open(UART_PORT0,¶m);
- void Init_PWM0(void)
- S_DRVPWM_TIME_DATA_T sPt;
- sPt.u8Mode = DRVPWM_AUTO_RELOAD_MODE;
- sPt.u32Frequency = 1000;
- sPt.u8HighPulseRatio =50;
- sPt.i32Inverter = 0;
- DrvPWM_Open();
- DrvPWM_SelectClockSource(DRVPWM_TIMER0, DRVPWM_EXT_12M);
- DrvPWM_SetTimerClk(DRVPWM_TIMER0, &sPt);
- DrvPWM_SetTimerIO(DRVPWM_TIMER0, 1);
- DrvGPIO_InitFunction(E_FUNC_PWM01);
- DrvPWM_Enable(DRVPWM_TIMER0, 1); /* Enable PWM timer 0 function. */
- int main (void)
- uint16_t i32ConversionData;
- // uint32_t i32ConversionData_Sum;
- //uint8_t IsFirst = 1;
- Init_System();
- Init_Uart();
- Init_PWM0();
- DrvGPIO_Open(E_GPA,Run_Led, E_IO_OUTPUT);
- DrvGPIO_ClrBit(E_GPA,Run_Led);
- DrvGPIO_InitFunction(E_FUNC_ADC1);
- DrvADC_Open(ADC_SINGLE_END, ADC_SINGLE_OP, 0x02, EXTERNAL_12MHZ, 3);
- printf("\n");
- printf("Driver version: %x\n", DrvADC_GetVersion());
- DrvADC_EnableSelfCalibration();
- while(DrvADC_IsCalibrationDone()==0);
- DrvADC_DisableSelfCalibration();
- while(1)
- DrvADC_StartConvert();
- while(DrvADC_IsConversionDone()==0);
- i32ConversionData = DrvADC_GetConversionData(1);
- printf("%d\n",i32ConversionData);
- delay_ms(1000);
- PWMA->CMR0 =(PWMA->CNR0+1)*(i32ConversionData*100/4096)/100-1;
- printf("PWMA->CMR0: %d\n", PWMA->CMR0);
- printf("PWMA->CNR0: %d\n", PWMA->CNR0);
