昨晚stm32f101遇到奇怪问题:外部中断函数总是重复进入
3429|3
 楼主| tomzxq 发表于 2012-4-16 10:46 | 显示全部楼层 |阅读模式
昨晚stm32f101遇到奇怪问题:外部中断函数总是重复进入,但是io绝对没有变化。相关代码如下
请大家指点。原来用stm32f103也是类似用法,这次真的郁闷了,清楚中断标志后还是会再次进来。
void EXTI15_10_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line13) != RESET)
   i=GPIO_ReadInputDataBit(RI_GPIO);
   if (i==0) noevent_counter=0;
   else noevent_counter++;
   /EXTI_ClearITPendingBit(EXTI_Line13);
void open_INT ( void ){
NVIC_InitTypeDef NVIC_InitStructure;
EXTI_InitTypeDef EXTI_InitStructure;
/* Enable the EXTI13 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* Connect EXTI Line1 to Pb.13 */
GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource13);
/* Configure EXTI Line4 to generate an interrupt on falling edge */
EXTI_InitStructure.EXTI_Line = EXTI_Line13;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;//EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
void GpioInputInit (void)
  // GPIO Init
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA |
    RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE);
  /* Configure the pc as input floating */
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_3 |GPIO_Pin_5 |GPIO_Pin_6 |GPIO_Pin_13;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 ;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0 |GPIO_Pin_1 |GPIO_Pin_13 ;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
 楼主| tomzxq 发表于 2012-4-16 10:50 | 显示全部楼层
补充说明,原来类似功能在stm32f103都用过,功能正常的,中断优先级也都没问题的。真的怀疑这次我的片子是不是坏了。
 楼主| tomzxq 发表于 2012-4-16 20:43 | 显示全部楼层
怎么没有回答,我描述的还算清楚吧?各位高手请进,香主请进
lut1lut 发表于 2012-4-17 15:31 | 显示全部楼层
配置PB.13的上升沿产生EXT13,PB.13的GPIO配置是浮空输入。
那你板子上PB.13有下拉伐?
