[STM32F3] STM32无法进入DMA发送完成中断
584|4
 楼主| kzlzqi 发表于 2022-11-16 22:26 | 显示全部楼层 |阅读模式
STM32 通过串口1接收上位机8个字节的数据 通过DMA发送到缓存
程序做好相关配置,通过调试助手下发8字节数据  程序一直无法进入DMA发送完成中断
请问是配置方面有什么问题吗  下面贴出主要的配置程序
 楼主| kzlzqi 发表于 2022-11-16 22:28 | 显示全部楼层
  1. //配置
  2. void NVIC_Config(void){
  3. NVIC_InitTypeDef NVIC_InitStructure;
  4. NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  5. //NVIC_InitStructure.NVIC_IRQChannel=USART1_IRQn;
  6. NVIC_InitStructure.NVIC_IRQChannel=DMA1_Channel5_IRQn;
  7. NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1;
  8. NVIC_InitStructure.NVIC_IRQChannelSubPriority=1;
  9. NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
  10. NVIC_Init(&NVIC_InitStructure);
  11. }
  12. void USART1_Config(void){
  13. GPIO_InitTypeDef GPIO_InitStructure;
  14. USART_InitTypeDef USART_InitStructure;
  15. RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
  16. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  17. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  18. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  19. GPIO_Init(GPIOA, &GPIO_InitStructure);
  20. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  21. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  22. GPIO_Init(GPIOA, &GPIO_InitStructure);
  23. USART_InitStructure.USART_BaudRate = 115200;
  24. USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  25. USART_InitStructure.USART_StopBits = USART_StopBits_1;
  26. USART_InitStructure.USART_Parity = USART_Parity_No ;
  27. USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  28. USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  29. USART_Init(USART1, &USART_InitStructure);
  30. USART_Cmd(USART1, ENABLE);
  31. USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE);
  32. //USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
  33. ////USART_GetFlagStatus(USART1,USART_FLAG_TC);
  34. }
  35. void USART1_DMA_Config(void)
  36. {
  37. extern uint8_t RECEBuf;
  38. extern uint8_t RECEBuf_Size;
  39. DMA_InitTypeDef DMA_InitStructure;
  40. RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
  41. DMA_DeInit(DMA1_Channel5);
  42. DMA_InitStructure.DMA_PeripheralBaseAddr=0x40013804;
  43. DMA_InitStructure.DMA_MemoryBaseAddr=(uint8_t)RECEBuf;
  44. DMA_InitStructure.DMA_DIR=DMA_DIR_PeripheralSRC;
  45. DMA_InitStructure.DMA_BufferSize=RECEBuf_Size;
  46. DMA_InitStructure.DMA_PeripheralInc=DMA_PeripheralInc_Disable;
  47. DMA_InitStructure.DMA_MemoryInc=DMA_MemoryInc_Enable;
  48. DMA_InitStructure.DMA_PeripheralDataSize=DMA_PeripheralDataSize_Byte;
  49. DMA_InitStructure.DMA_MemoryDataSize=DMA_MemoryDataSize_Byte;
  50. DMA_InitStructure.DMA_Mode=DMA_Mode_Normal;
  51. DMA_InitStructure.DMA_Priority=DMA_Priority_VeryHigh;
  52. DMA_InitStructure.DMA_M2M=DMA_M2M_Disable;
  53. DMA_Init(DMA1_Channel5,&DMA_InitStructure);
  54. DMA_Cmd(DMA1_Channel5,ENABLE);
  55. DMA_ITConfig(DMA1_Channel5,DMA_IT_TC,ENABLE);
  56. }
  57. //中断处理
  58. void DMA1_Channel5_IRQHandler(void)
  59. {
  60.     printf("c");
  61.     if(DMA_GetFlagStatus(DMA1_IT_TC5))
  62.         {
  63. //        a=0;
  64.         uint8_t data;
  65.         DMA_ClearITPendingBit(DMA1_IT_GL5);
  66.             data=DMA_GetCurrDataCounter(DMA1_Channel5);
  67.         DMA_Cmd(DMA1_Channel5,DISABLE);
  68.     DMA_SetCurrDataCounter(DMA1_Channel5,8);
  69.     DMA_Cmd(DMA1_Channel5,ENABLE);
  70.             printf("%d",data);
  71.         printf("%d",RECEBuf[0]);
  72.         }
  73. }
xiaoqi000 发表于 2022-11-20 15:54 | 显示全部楼层
软件对了暂时没有看到有什么问题。
最好提供一下,在没有使用DMA时,USART1有没有能正常接收到数据,以证明硬件连接是否有问题。
xiaoqi000 发表于 2022-11-20 16:01 | 显示全部楼层
确认USART1能正常接收,你可以接下来再测试,加入DMA,但是不开DMA中断,去读取RECEBuf,看是否能正常接收数据存在DMA中
SantaBunny 发表于 2023-2-21 12:31 | 显示全部楼层
使用DMA时,USART1有没有能正常接收到数据,证明硬件连接是否有问题。
