[STM32H7] STM32H743VIT6
391|0
 楼主| flycamelaaa 发表于 2022-11-21 14:57 | 显示全部楼层 |阅读模式
你好!
       我用cubeMX产生USART2 DMA 发送,但发现没有出来。我看了很多次程序,没有发现问题,用普通方式发送数据,没有问题,DMA方式不行,采用DMA1,时钟也设置了,
        /* USART2_TX Init */
        hdma_usart2_tx.Instance                               = DMA1_Stream3;
        hdma_usart2_tx.Init.Request                           = DMA_REQUEST_USART2_TX;
        hdma_usart2_tx.Init.Direction                         = DMA_MEMORY_TO_PERIPH;
        hdma_usart2_tx.Init.PeriphInc                         = DMA_PINC_DISABLE;
        hdma_usart2_tx.Init.MemInc                            = DMA_MINC_ENABLE;
        hdma_usart2_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
        hdma_usart2_tx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
        hdma_usart2_tx.Init.Mode                             = DMA_NORMAL;
        hdma_usart2_tx.Init.Priority                         = DMA_PRIORITY_LOW;
        hdma_usart2_tx.Init.FIFOMode                         = DMA_FIFOMODE_DISABLE;
        hdma_usart2_tx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;
        hdma_usart2_tx.Init.MemBurst      = DMA_MBURST_SINGLE;
        hdma_usart2_tx.Init.PeriphBurst   = DMA_PBURST_SINGLE;
        HAL_DMA_DeInit(&hdma_usart2_tx);
        if (HAL_DMA_Init(&hdma_usart2_tx) != HAL_OK)
        __HAL_LINKDMA(&UART2_Handler,hdmatx,hdma_usart2_tx);
不知道哪儿出了问题?USART3 DMA就没有问题,难道USART2 DMA 发送不行?
