[WIFI模块] IPQ4019 IPQ4029 Quectel support Industrial Wifi Router Wallys/DR40X9
1836|0
 楼主| lilywallys 发表于 2022-11-23 13:37 | 显示全部楼层 |阅读模式
Today,let’s talk about the wireless communication technology and its application.
Wireless communication technology and application
Wireless communication technology is widely used in different research fields. This book mainly introduces the key technologies, new technologies and related applications of wireless communication system. APPLICATIONS+ Profi WiFi hotspot coverage+ Commercial radio coverage+ Hotel Wireless application+ Country coverage+ Internet for passengers (bus, train, plane, …)+ Security Surveillance+ Some special scene application+ Heavy-duty industrial environment useThe main contents include: key technologies of wireless communication, RFID wireless communication technology, ZigBee wireless communication technology, WLAN wireless communication technology, Bluetooth wireless communication technology, mobile communication technology, other wireless communication technology, future development trend of wireless communication, etc.Let's take a look at **WLAN wireless communication technology**:A WLAN is a Wireless local area network (LAN) built using wireless technology. WLAN in a broad sense refers to a network that uses radio waves, lasers, infrared and other wireless signals to replace part or all of the transmission media in the priority LAN.Using WLAN technology, users can easily access the wireless network and move freely within the coverage area of the wireless network, completely getting rid of the shackles of the wired network.
When several devices are connected to the same AP, they can communicate with each other.Wireless is more insecure than wired, so there is no security and no wireless. Wireless is generally used to encrypt data and verify access devices.
802.11AC and wallys routerboard DR40x9
Wallys Routerboard DR40X9 is a professional routerboard with industrial-grade IPQ4019/IPQ4029 chipset. It features integrated 2x 2 5G high power radio module and 2x2 2.4G high power radio module, which supports 4.940GHz to 5.825GHz frequency range, and can support 2 x 5G MMCX connectors and 2x2.4G MMCX. It supports 5MHz/10MHz/20MHz/40MHz/80MHz bandwidth, which enables you to have stable data transmission rate. It also supports 11ABGN/AC and fixed data rate.
Click below the link for more information about DR40X9.
https://www.wallystech.com/Routerboard/DR40X9-Qualcomm-IPQ-4019-4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html
Wallys Communications (Suzhou ) Co., LTD is mainly engaged in the research and development and production of wireless communication products,such as Routerboard,Network Card,Industrial Wireless AP,Antenna etc.OEM/ODM/JDM services for customers supported.
With our experienced R&D engineer team,which with a demonstratedhistory of working in the wireless industry,you can explore the project with RF and embedded communications,network protocol,firmware,openwrt,linux system,development,analog and Digital Circuit Design,Network Processors,Power supplies,PCB design and layout with us.
Welcome to email us for more information.
Email:sales1@wallystech.com
Wallys Communications (SuZhou) Co.,Ltd
http://www.wallystech.com
