hc32f460 SPI读取一直为0
1525|0
 楼主| jys0305 发表于 2022-12-4 18:29 | 显示全部楼层 |阅读模式
使用hc32f460,SPI1,发送0x55,测试时钟和MOSI引脚电平,变化正常。miso脚一直是高电平,但是SPI读出来数据一直是0x00,按理说应该是0xff。SPI 配置如下
#define SD_SPI_PERIPH_CLK         FCG1_PERIPH_SPI1
#define SPI_SD                    CM_SPI1
#define SD_SPI_CS_PORT            GPIO_PORT_A
#define SD_SPI_CS_PIN             GPIO_PIN_04
#define SD_SPI_PORT              GPIO_PORT_A
#define SD_SPI_SCK_PIN           GPIO_PIN_05
#define SD_SPI_MISO_PIN          GPIO_PIN_06
#define SD_SPI_MOSI_PIN          GPIO_PIN_07
#define SD_SPI_SCK_PIN_FUNC          (GPIO_FUNC_43)
#define SD_SPI_MOSI_PIN_FUNC         (GPIO_FUNC_40)
#define SD_SPI_MISO_PIN_FUNC            (GPIO_FUNC_41)
static void App_SPIxCfg(void)
   stc_gpio_init_t stcGpioInit;
    stc_spi_init_t stcSpiInit;
    stc_spi_delay_t stcSpiDelayCfg;
    (void)GPIO_StructInit(&stcGpioInit);
    stcGpioInit.u16PinDrv = PIN_HIGH_DRV;
    (void)GPIO_Init(SD_SPI_CS_PORT,  SD_SPI_CS_PIN,  &stcGpioInit);
    (void)GPIO_Init(SD_SPI_PORT, SD_SPI_SCK_PIN, &stcGpioInit);
    (void)GPIO_Init(SD_SPI_PORT, SD_SPI_MOSI_PIN, &stcGpioInit);
    stcGpioInit.u16PinDir = PIN_DIR_OUT;
    GPIO_SetFunc(SPI_SCK_PORT, SPI_SCK_PIN, SD_SPI_SCK_PIN_FUNC);
    GPIO_SetFunc(SPI_MOSI_PORT, SPI_MOSI_PIN, SD_SPI_MOSI_PIN_FUNC);
    GPIO_SetFunc(SPI_MISO_PORT, SPI_MISO_PIN, SD_SPI_MISO_PIN_FUNC);
    /* Clear initialize structure */
    (void)SPI_StructInit(&stcSpiInit);
    (void)SPI_DelayStructInit(&stcSpiDelayCfg);
    /* Configure peripheral clock */
    FCG_Fcg1PeriphClockCmd(SD_SPI_PERIPH_CLK, ENABLE);
    /* SPI De-initialize */
    SPI_DeInit(SPI_UNIT);
    /* Configuration SPI structure */
    stcSpiInit.u32WireMode          = SPI_3_WIRE;
    stcSpiInit.u32TransMode         = SPI_FULL_DUPLEX;
    stcSpiInit.u32MasterSlave       = SPI_MASTER;
    stcSpiInit.u32ModeFaultDetect   = SPI_MD_FAULT_DETECT_DISABLE;
    stcSpiInit.u32Parity            = SPI_PARITY_INVD;
    stcSpiInit.u32SpiMode           = SPI_MD_0;
    stcSpiInit.u32BaudRatePrescaler = SPI_BR_CLK_DIV4;
    stcSpiInit.u32DataBits          = SPI_DATA_SIZE_8BIT;
    stcSpiInit.u32FirstBit          = SPI_FIRST_MSB;
    (void)SPI_Init(SPI_UNIT, &stcSpiInit);
    stcSpiDelayCfg.u32IntervalDelay = SPI_INTERVAL_TIME_8SCK;
    stcSpiDelayCfg.u32ReleaseDelay  = SPI_RELEASE_TIME_8SCK;
    stcSpiDelayCfg.u32SetupDelay    = SPI_SETUP_TIME_1SCK;
    (void)SPI_DelayTimeConfig(SPI_UNIT, &stcSpiDelayCfg);
    SPI_Cmd(SPI_UNIT, ENABLE);
