[无线通信] Wallys/DR9074E-Qualcomm Atheros QCN9074(QCN9024)/ 4x4 MU-MIMO Dual Band Wireless Module
1446|0
 楼主| Cindy@wallys 发表于 2022-12-7 16:33 | 显示全部楼层 |阅读模式
DR9074E
https://www.wallystech.com/Network_Card/DR9074E-Qualcomm-QCN9074-QCN9024-WiFi6-and-WiFi6E-4x4-MU-MIMO-Dual-Band-WiFi-Module-MiniPCIe.html
Features
■ Qualcomm Atheros QCN90X4
■ Maxim Tx power 20dBm per chain
■ Date Rateup to 4949Mbps
■ Support  5.180~5.825Ghz or 5.925GHz-7.125GHz or  5.180GHz- 7.125GHz
■ MiniPCIe connector
■ PCI Express 3.0 Interface
The wi-fi tuner for the QCN90X4 is designed for security surveillance, commercial radio coverage and some special scene application. It supports porter’s power measurement and IEEE 802.11g/n 5.x GHz output with maximum tx power of 20dBm per chain. The bandwidth rateup is up to 4949Mbps based on the selected interface test rate. This new model is a plus product at this season to meet the out growth and development needs on mobile communications in many countries around the world.
Applications
■ Security Surveillance
■ Commercial radio coverage
■ Hotel Wireless application
■ Forest fire protection engineering
■ Country coverage
■ Some special scene application
Absolute Maximum Rating
Parameter
Rating
Unit
Operating Temperature Range
-20 to 70
ºC
Storage Temperature Range
-40 to 90
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
Chipset
WLAN Host Interface
System Memory
2Mbit serial I²C bus EEPROM
Standard Operating Voltage
3.3V
Operating Systems
QSDK
Host Interface
MiniPCIE
Antenna Cable / Port
4 x MMCX Connectors,4T4R
Frequency Range
5.180GHz-5.852GHz or 5.952GHz-7.125GHz
Data Rates for WALN
Maxim TX power 20dBm per chain, up to 4949Mbps
Channel Spectrum Widths for WLAN
Support 20/40/80/160MHz
Modulation Techniques
OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range
Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity
Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification
TBD
Power Consumption
15WMaximum),9.5W(Normally)
Dimensions (WxHxD)
30mm x 50mm x 14.5mm
For more products please visit: https://www.wallystech.com/product.html
Follow us in the Youtube: https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
