[发行版] Industrial Edge controller for IIoT
3411|0
 楼主| wenming 发表于 2022-12-14 12:18 | 显示全部楼层 |阅读模式
Overview
EdgeLogix modular,open-archiecture edge controllers manage complex interfaces
across assets and devices or  into the cloud directly, with legacy and next generation industry control system.
EdgeLogix 1200 provides performance and scalability for a wide range of industrial applications, including
motion control, networking, IO and IIoT in a compact  model, as while as the advantages of traditional
IEC-61131-3 programming with the flexibility of Linux.
The EdgeLogix 1200 Series covers all the functions required of logic computing, including easy operation and compatibility with
a variety of control and measurement applications. This flexible device for ultra-reliable measurement and control of industry
users the customized logic and control needed to meet application requirements. Industry-leading configurability and
programmability fulfill standard to complex requirements while secure, built-in flow measurement calculations make it
easier than ever to prove compliance. In addition, cloud-enabled functionality for licensing simplifies day-to-day operations.
Digitally transform your operation by streamlining complex processes with the agile, intuitive EdgeLogix  . This new controller is
also part of OpenEmbed's next-generation EdgeLogix Series measurement and control platform that offers a common
set of configuration tools, to expedite setup and facilitate commonly performed tasks.
Features:
High Performacne CPU
Robust system design
Display for commissioning and diagnostics
Flexbility of  local BUS extension
5G ready WWAN connectivity
TSN for next-gen industry network
Built-in IT connectivity: DHCP/DNS, OPC UA and Web service
Neural Processing Unit (NPU) enables Artificial Intelligence for automation
CPU
EdgeLogix1240:Raspberry pi CM4
Memory
4GB RAM
Storage
On board emmc 32GB
Wireless​
2.4 GHz, 5.0 GHz IEEE 802.11 b/g/n/ac
Bluetooth 5.0, BLE
Video Interface​
HDMI 2.0a (up to 4kp60 supported)
Interfaces
3× RJ45 ethernet port support 10/100M/1000M
Mini PCIe socket with SIM card for 4G/LTE WWAN
Mini PCIe socket with SPI interface for lora WAN
2 x USB 2.0Port
1 x HDMI 2.0
2× DI
2x DO
1 x isolated RS485
1 x RS232
Signal board:
All signals are isolated from main CPU
DO*10
DI *10
RS485*4
RS232*2
CAN BUS*2 , with CAN-FD capacity
Extra features
RTC
Stand alone Watch dog timer
Atecc608a(optional)
Dimensions: 140 (W) x 124 (H) x 376 (T) mm
Power supply: DC 10.8-36 V
Operation temperaturey:  -20..+60 °C
Storage temperature y: -40..+70 °C
APPs:
EdgeLogix 1200 series comes with various options
and is customizable to your needs.
• IoT gateway
• SCADA
• Cellular router
• Edge computing
• Building Automation
• Programable logic controller
• Gateway for field bus and IO
• Industrial Automation for industry 4.0
个人签名:嵌入式Linux工业控制板,提供ODM与OEM,只做批量,不卖开发板! 欧比特测控   www.OpenEmbed.com
108
