[DemoCode下载] 利用定时器实现类似于PWM呼吸灯调光
1315|15
 楼主| 598330983 发表于 2022-12-20 20:33 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 3 $
  5. * $Date: 15/09/02 10:03a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate how to set GPIO pin mode and use pin data control RGB LED.
  7. * @note
  8. * Copyright (C) 2019 Nuvoton Technology Corp. All rights reserved.
  9. *
  10. ******************************************************************************/
  11. #include "stdio.h"
  12. #include "M451Series.h"
  13. #include "NuEdu-Basic01.h"
  14. #define PLL_CLOCK       72000000
  15. /*---------------------------------------------------------------------------------------------------------*/
  16. /* Global variables        */
  17. /*---------------------------------------------------------------------------------------------------------*/
  18. uint32_t LED1_R, LED1_G, LED1_B, Blink,brea=0,LED_cnt=0,brea_cnt=0;
  19. void SYS_Init(void)
  20. {
  21.     /*---------------------------------------------------------------------------------------------------------*/
  22.     /* Init System Clock        */
  23.     /*---------------------------------------------------------------------------------------------------------*/
  24.     /* Enable HIRC clock (Internal RC 22.1184MHz) */
  25.     CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
  26.     /* Wait for HIRC clock ready */
  27.     CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
  28.     /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
  29.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
  30.     /* Enable HXT clock (external XTAL 12MHz) */
  31.     CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
  32.     /* Wait for HXT clock ready */
  33.     CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
  34.     /* Set core clock as PLL_CLOCK from PLL */
  35.     CLK_SetCoreClock(PLL_CLOCK);
  36.     /* Enable UART module clock */
  37.     CLK_EnableModuleClock(UART0_MODULE);
  38.     /* Select UART module clock source as HXT and UART module clock divider as 1 */
  39.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
  40.     /*---------------------------------------------------------------------------------------------------------*/
  41.     /* Init I/O Multi-function        */
  42.     /*---------------------------------------------------------------------------------------------------------*/
  43.     /* Set PD multi-function pins for UART0 RXD(PD.6) and TXD(PD.1) */
  44.     SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
  45.     SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
  46. }
  47. void UART0_Init()
  48. {
  49.     /*---------------------------------------------------------------------------------------------------------*/
  50.     /* Init UART        */
  51.     /*---------------------------------------------------------------------------------------------------------*/
  52.     /* Reset UART module */
  53.     SYS_ResetModule(UART0_RST);
  54.     /* Configure UART0 and set UART0 baud rate */
  55.     UART_Open(UART0, 115200);
  56. }
  57. void TMR1_IRQHandler(void)
  58. {
  59.           uint32_t LED_duty,RLED,BLED,GLED,LED_brea;
  60.     if(TIMER_GetIntFlag(TIMER1) == 1) {
  61.         /* Clear Timer1 time-out interrupt flag */
  62.         TIMER_ClearIntFlag(TIMER1);
  63.         LED_cnt++;
  64.         LED_duty=LED_cnt%100;
  65.         if((brea==1)&&((brea_cnt%2)==0))
  66.             LED_brea=100-(LED_cnt/100);
  67.         else if(brea==1)
  68.             LED_brea=LED_cnt/100;
  69.         else
  70.             LED_brea=0;
  71.         RLED=((int32_t)(LED1_R-LED_duty-LED_brea)>0)?1:0;
  72.         BLED=((int32_t)(LED1_B-LED_duty-LED_brea)>0)?1:0;
  73.         GLED=((int32_t)(LED1_G-LED_duty-LED_brea)>0)?1:0;
  74.         if(LED_cnt>=(Blink*1000)) {
  75.             RLED=0;
  76.             BLED=0;
  77.             GLED=0;
  78.         }
  79.         //PC->DOUT = (PC->DOUT&(~(BIT9|BIT10|BIT11)))|(RLED<<9)|(GLED<<10)|(BLED<<11);
  80.         PC->DOUT = (PC->DOUT|BIT9|BIT10|BIT11)&(~((RLED<<9)|(GLED<<10)|(BLED<<11)));
  81.         if(LED_cnt==10000) {
  82.             LED_cnt=0;
  83.             brea_cnt++;
  84.         }
  85.     }
  86. }
  87. /*---------------------------------------------------------------------------------------------------------*/
  88. /*  Main Function        */
  89. /*---------------------------------------------------------------------------------------------------------*/
  90. int32_t main(void)
  91. {
  92.     /* Unlock protected registers */
  93.     SYS_UnlockReg();
  94.     /* Init System, peripheral clock and multi-function I/O */
  95.     SYS_Init();
  96.     /* Lock protected registers */
  97.     //SYS_LockReg();
  98.     /* Init UART0 for printf */
  99.     UART0_Init();
  100.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
  101.     printf("LED test\n\r");
  102.     GPIO_SetMode(PC, BIT11, GPIO_MODE_OUTPUT); //BLED
  103.     GPIO_SetMode(PC, BIT10, GPIO_MODE_OUTPUT); //GLED
  104.     GPIO_SetMode(PC, BIT9, GPIO_MODE_OUTPUT);  //RLED
  105.     /* Enable peripheral clock */
  106.     CLK_EnableModuleClock(TMR1_MODULE);
  107.     CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1SEL_HIRC, 0);
  108.     TIMER_Open(TIMER1, TIMER_PERIODIC_MODE, 10000);
  109.     TIMER_EnableInt(TIMER1);
  110.     /* Enable Timer1 NVIC */
  111.     NVIC_EnableIRQ(TMR1_IRQn);
  112.     /*setting RGB LED*/
  113.     LED1_R=100;
  114.     LED1_G=100;
  115.     LED1_B=100;
  116.     Blink=10;
  117.     brea=1;
  118.     TIMER_Start(TIMER1);
  119.     while(1);
  120. }
 楼主| 598330983 发表于 2022-12-20 20:34 | 显示全部楼层
单片机上的PWM往往很宝贵,而IO却很丰富,有时候想实现呼吸灯效果,我们就可以用上面的方法借助定时器实现,由于时钟频率很高,所以这个中间的误差可以忽略。
小夏天的大西瓜 发表于 2022-12-24 21:26 | 显示全部楼层
楼主想法很好,当灯的亮灭比例为1:0时,为最亮时刻;亮灭比例为0:1时,为最暗时刻,表现为灭,过程中的时刻就是逐渐变化的一个过程,其实就是利用定时器中断人为做出了一个PWM
heisexingqisi 发表于 2022-12-25 15:02 | 显示全部楼层
有点难懂啊。
AdaMaYun 发表于 2022-12-27 10:36 | 显示全部楼层
使用C语言控制单片机IO交替输出高低电平,实现LED小灯的闪烁效果
IO输出的高低电平持续时间都是10个单位,一个完整的周期内,LED小灯的亮灭时间都是相等的。由此可见,使用单片机控制小灯亮度,就是控制一个周期内,LED小灯的亮灭持续时间长短而已。
LOVEEVER 发表于 2022-12-27 15:40 | 显示全部楼层
挺好的IDEA,用定时器模拟输出的PWM挺好
小小蚂蚁举千斤 发表于 2022-12-30 20:38 | 显示全部楼层
楼主方案挺好的,确实在PWM口比较紧缺的时候此方法可以说是非常好用
tpgf 发表于 2023-1-5 10:10 | 显示全部楼层
并没有真的使用pwm 而是模拟了一下pwm的效果是吗
木木guainv 发表于 2023-1-5 10:25 | 显示全部楼层
我喜欢用定时器 这样可以随时修改参数  感觉比用pwm简单点
晓伍 发表于 2023-1-5 10:43 | 显示全部楼层
很多简单的应用实际上并不需要使用pwm模块 使用io有时候会更加灵活
八层楼 发表于 2023-1-5 11:18 | 显示全部楼层
这种简单的应用使用io是非常合适的 灵活 而且不浪费资源
OKAKAKO 发表于 2023-1-5 12:02 | 显示全部楼层
没有真的使用pwm 确达到了pwm的效果,而且灵活,确实可以
中国龙芯CDX 发表于 2023-1-5 12:33 | 显示全部楼层
IO实现pwm的效果,很实用
guanjiaer 发表于 2023-1-5 12:43 | 显示全部楼层
一种非常好的思路 而且这样处理感觉会更加的灵活
heimaojingzhang 发表于 2023-1-5 12:51 | 显示全部楼层
IO输出的高低电平持续时间都是10个单位, ...
是的 这就是他的本质 所以使用不使用pwm都不是那么重要
星辰大海不退缩 发表于 2023-1-6 18:50 | 显示全部楼层
说的很对这个就是亮灭的原理,其实也是PWM调压的原理
