[开发资料] 单片机低功耗的关键就是休眠,休眠的最高境界就是掉电模式
536|0
 楼主| Ghorey 发表于 2022-12-21 20:00 | 显示全部楼层 |阅读模式
* @file     main.c
* @version  V3.00
* $Revision: 2 $
* $Date: 16/10/25 4:29p $
* @brief    Show how to wake up system from Power-down mode by GPIO interrupt.
* @note
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include
#include "NUC029xGE.h"
#define PLLCTL_SETtiNG  CLK_PLLCTL_72MHz_HXT
#define PLL_CLOCK       72000000
/*  Function for System Entry to Power Down Mode                                                           */
void PowerDownFunction(void)
    /* Check if all the debug messages are finished */
    UART_WAIT_TX_EMPTY(UART0);
    /* Enter to Power-down mode */
    CLK_PowerDown();
* @brief       PortA/PortB IRQ
* @param       None
* @return      None
* @Details     The PortA/PortB default IRQ, declared in startup_NUC029xGE.s.
void GPAB_IRQHandler(void)
    /* To check if PB.3 interrupt occurred */
    if(GPIO_GET_INT_FLAG(PB, BIT3))
        GPIO_CLR_INT_FLAG(PB, BIT3);
        printf("PB.3 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PB interrupts */
        PB->INTSRC = PB->INTSRC;
        printf("Un-expected interrupts.\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set multi-function pins for UART0 RXD and TXD */
    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU @ %d Hz\n", SystemCoreClock);
    printf("+-------------------------------------------------------+\n");
    printf("|    GPIO Power-Down and Wake-up by PB.3 Sample Code    |\n");
    printf("+-------------------------------------------------------+\n\n");
    /* Configure PB.3 as Input mode and enable interrupt by rising edge trigger */
    GPIO_SetMode(PB, BIT3, GPIO_MODE_INPUT);
    GPIO_EnableInt(PB, 3, GPIO_INT_RISING);
    NVIC_EnableIRQ(GPAB_IRQn);
    /* Enable interrupt de-bounce function and select de-bounce sampling cycle time is 1024 clocks of LIRC clock */
    GPIO_SET_DEBOUNCE_TIME(GPIO_DBCTL_DBCLKSRC_LIRC, GPIO_DBCTL_DBCLKSEL_1024);
    GPIO_ENABLE_DEBOUNCE(PB, BIT3);
    /* Unlock protected registers before entering Power-down mode */
    SYS_UnlockReg();
    /* Waiting for PB.3 rising-edge interrupt event */
    printf("Enter to Power-Down ......\n");
    PowerDownFunction();
    printf("System waken-up done.\n\n");
    while(1);
/*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
