可控硅触发时间实验
508|0
 楼主| 34af9uc 发表于 2022-12-23 20:49 | 显示全部楼层 |阅读模式
/***********STC8H8K64U两位数码管显示***************/
/*****************QQ:74145445**********************/
/*****************快手:共同学习stm8****************/
/*****************20221221*************************/
/****************可控硅触发时间********************/
#include<STC8H.H>
sbit                led_1_a                =P2^4;
sbit                led_1_b                =P2^3;
sbit                led_1_c                =P4^6;
sbit                led_1_d                =P7^7;
sbit                led_1_e                =P7^6;
sbit                led_1_f                =P2^6;
sbit                led_1_g                =P2^7;
sbit                led_1_dp        =P0^0;
sbit                led_1_3                =P4^5;
sbit                led_1_5                =P2^5;
sbit                led_2_a                =P4^1;
sbit                led_2_b                =P7^3;
sbit                led_2_c                =P0^5;
sbit                led_2_d                =P5^2;
sbit                led_2_e                =P0^4;
sbit                led_2_f                =P4^3;
sbit                led_2_g                =P4^4;
sbit                led_2_dp        =P0^6;
sbit                led_2_3                =P5^3;
sbit                led_2_5                =P4^2;
sbit                key_1                =P3^4;
sbit                key_2                =P3^5;
sbit                key_3                =P3^2;
sbit                key_4                =P3^3;
sbit                out_1                =P1^3;
unsigned char code led[]={
        0x3F,0x06,0x5B,0x4F,0x66,0x6D,
        0x7D,0x07,0x7F,0x6F}; // 0~9
void xianshi();
void yanshi();
void anjian();
void chufa();
unsigned char xianshi_a1;
unsigned char xianshi_shi,xianshi_ge;
void main()
P0M0        |=(1<<0)+(1<<5)+(1<<4)+(1<<6);
P0M1        &=~((1<<0)+(1<<5)+(1<<4)+(1<<6));
P1M0        |=1<<3;
P1M1        &=~(1<<3);
P2M0        |=(1<<5)+(1<<4)+(1<<3)+(1<<6)+(1<<7);
P2M1        &=~((1<<5)+(1<<4)+(1<<3)+(1<<6)+(1<<7));
P3M0        &=~((1<<4)+(1<<5)+(1<<2)+(1<<3));                //输入
P3M1        |=(1<<4)+(1<<5)+(1<<2)+(1<<3);                //输入
P4M0        |=(1<<6)+(1<<5)+(1<<1)+(1<<3)+(1<<4)+(1<<2);
P4M1        &=~((1<<6)+(1<<5)+(1<<1)+(1<<3)+(1<<4)+(1<<2));
P5M0        |=(1<<2)+(1<<3);
P5M1        &=~((1<<2)+(1<<3));
P7M0        |=(1<<7)+(1<<6)+(1<<3);
P7M1        &=~((1<<7)+(1<<6)+(1<<3));
out_1=0;
while(1)
xianshi();
anjian();
yanshi();
chufa();
void yanshi()
unsigned int        y;
unsigned char z;
for(y=1000;y>0;y--)
        for(z=200;z>0;z--);
void xianshi()
xianshi_shi                =xianshi_a1/10;
xianshi_ge                =xianshi_a1%10;
xianshi_shi                =led[xianshi_shi];                //取回十位的模
xianshi_ge                =led[xianshi_ge];                        //取回个位的模
led_1_3=1;
led_1_5=1;
if(xianshi_shi&(1<<0)){led_1_a=0;}else{led_1_a=1;}
if(xianshi_shi&(1<<1)){led_1_b=0;}else{led_1_b=1;}
if(xianshi_shi&(1<<2)){led_1_c=0;}else{led_1_c=1;}
if(xianshi_shi&(1<<3)){led_1_d=0;}else{led_1_d=1;}
if(xianshi_shi&(1<<4)){led_1_e=0;}else{led_1_e=1;}
if(xianshi_shi&(1<<5)){led_1_f=0;}else{led_1_f=1;}
if(xianshi_shi&(1<<6)){led_1_g=0;}else{led_1_g=1;}
if(xianshi_shi&(1<<7)){led_1_dp=0;}else{led_1_dp=1;}
led_2_3=1;
led_2_5=1;
if(xianshi_ge&(1<<0)){led_2_a=0;}else{led_2_a=1;}
if(xianshi_ge&(1<<1)){led_2_b=0;}else{led_2_b=1;}
if(xianshi_ge&(1<<2)){led_2_c=0;}else{led_2_c=1;}
if(xianshi_ge&(1<<3)){led_2_d=0;}else{led_2_d=1;}
if(xianshi_ge&(1<<4)){led_2_e=0;}else{led_2_e=1;}
if(xianshi_ge&(1<<5)){led_2_f=0;}else{led_2_f=1;}
if(xianshi_ge&(1<<6)){led_2_g=0;}else{led_2_g=1;}
if(xianshi_ge&(1<<7)){led_2_dp=0;}else{led_2_dp=1;}
void anjian()
if(key_1==0)                //加1
        xianshi_a1++;if(xianshi_a1>99){xianshi_a1=0;}
        while(key_1==0);
if(key_2==0){xianshi_a1--; if(xianshi_a1>99){xianshi_a1=99;}}                //减1
if(key_4==0)                //加10
        xianshi_a1 +=10;if(xianshi_a1>99){xianshi_a1=0;}
        while(key_1==0);
void chufa()
unsigned char a1;
unsigned int b1;
        unsigned char i, j;
if(key_3==0)
        for(a1=100;a1>0;a1--)
        if(key_3==0)
                        while(key_3==0);                //等待松手
                        out_1=1;
                        for(b1=xianshi_a1;b1>0;b1--)
                                for(i=65;i>0;i--)
                                        for(j=15;j>0;j--);
                        out_1=0;
8h8kled.zip
1.2 KB, 下载次数: 0
8h8kled.zip
720 Bytes, 下载次数: 0
319
