[DemoCode下载]
GPIO高效的外部中断
377|2
xinxianshi|  楼主 | 2022-12-24 17:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 10 $
* $Date: 16/06/08 1:28p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate how to use GPIO external interrupt function.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC123.h"
#define HCLK_CLOCK   72000000
* @brief       External INT0 IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The External INT0(PB.14) default IRQ, declared in startup_NUC123.s.
void EINT0_IRQHandler(void)
    /* For PB.14, clear the INT flag */
    GPIO_CLR_INT_FLAG(PB, BIT14);
    printf("EINT0 occurred.\n");
* @brief       External INT1 IRQ
* @param       None
* @return      None
* @details     The External INT1(PB.15) default IRQ, declared in startup_NUC123.s.
void EINT1_IRQHandler(void)
    /* For PB.15, clear the INT flag */
    GPIO_CLR_INT_FLAG(PB, BIT15);
    printf("EINT1 occurred.\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable XT1_OUT(PF0) and XT1_IN(PF1) */
    SYS->GPF_MFP &= ~(SYS_GPF_MFP_PF0_Msk | SYS_GPF_MFP_PF1_Msk);
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as HCLK_CLOCK */
    CLK_SetCoreClock(HCLK_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD(PB.0) and TXD(PB.1) */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD);
    /* Set GPB multi-function pins for INT0(PB.14) and INT1(PB.15) */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB14_Msk | SYS_GPB_MFP_PB15_Msk);
    SYS->ALT_MFP &= ~SYS_ALT_MFP_PB15_Msk;
    SYS->GPB_MFP |= (SYS_GPB_MFP_PB14_INT0 | SYS_GPB_MFP_PB15_INT1);
    SYS->ALT_MFP |= SYS_ALT_MFP_PB15_INT1;
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+------------------------------------------------------------+\n");
    printf("|    GPIO EINT0/EINT1 Interrupt Sample Code                  |\n");
    printf("+------------------------------------------------------------+\n\n");
    /* GPIO External Interrupt Function Test                                                               */
    printf("EINT0(PB.14) and EINT1(PB.15) are used to test interrupt\n");
    /* Configure PB.14 as EINT0 pin and enable interrupt by falling edge trigger */
    GPIO_SetMode(PB, BIT14, GPIO_PMD_INPUT);
    GPIO_EnableEINT0(PB, 14, GPIO_INT_FALLING);
    NVIC_EnableIRQ(EINT0_IRQn);
    /* Configure PB.15 as EINT1 pin and enable interrupt by rising and falling edge trigger */
    GPIO_SetMode(PB, BIT15, GPIO_PMD_INPUT);
    GPIO_EnableEINT1(PB, 15, GPIO_INT_BOTH_EDGE);
    NVIC_EnableIRQ(EINT1_IRQn);
    /* Waiting for interrupts */
    while(1);
/*** (C) COPYRIGHT 2014~2015 Nuvoton Technology Corp. ***/
xinxianshi|  楼主 | 2022-12-24 17:28 | 只看该作者
这个外部中断没有与其他的共用中断入口,所以高效。重要的场合才使用。
小夏天的大西瓜| | 2022-12-24 20:43 | 只看该作者
中断就配置了一下,中断函数做了一个print,中断应该还把优先级配置一下,更能显示出高效
