[DemoCode下载]
PWM定时器捕获功能
910|5
gaoyang9992006|  楼主 | 2022-12-24 17:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 8 $
* $Date: 16/07/22 10:25a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate how to use PWMA Channel 0 captures PWMA Channel 1 Waveform.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC123.h"
/* Macro, type and constant definitions        */
#define PLLCON_SETTING      CLK_PLLCON_72MHz_HXT
#define PLL_CLOCK           72000000
/* Global variables        */
* @brief       PWMA IRQ Handler
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     ISR to handle PWMA interrupt event
void PWMA_IRQHandler(void)
//    uint32_t u32PwmIntFlag;
    uint32_t u32CapIntFlag1;
    /* Handle PWMA Capture function */
    u32CapIntFlag1 = PWMA->CCR0;
    /* PWMA channel 0 Capture interrupt */
    if(u32CapIntFlag1 & PWM_CCR0_CAPIF0_Msk)
        PWMA->CCR0 &= (PWM_CCR_MASK | PWM_CCR0_CAPIF0_Msk);
/* Capture function to calculate the input waveform information                         */
/* u32Count[4] : Keep the internal counter value when input signal rising / falling     */
/*               happens        */
/* time    A    B     C     D                                                           */
/*           ___   ___   ___   ___   ___   ___   ___   ___                              */
/*      ____|   |_|   |_|   |_|   |_|   |_|   |_|   |_|   |_____                        */
/* index              0 1   2 3                                                         */
/* The capture internal counter down count from 0x10000, and reload to 0x10000 after    */
/* input signal falling happens (Time B/C/D)                                            */
void CalPeriodTime(PWM_T *PWM, uint32_t u32Ch)
    uint16_t u32Count[4];
    uint32_t u32i;
    uint16_t u16RisingTime, u16FallingTime, u16HighPeriod, u16LowPeriod, u16TotalPeriod;
    /* Clear Capture Falling Indicator (Time A) */
    PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH);
    /* Wait for Capture Falling Indicator  */
    while(PWM_GetCaptureIntFlag(PWM, u32Ch) < 2);
    /* Clear Capture Falling Indicator (Time B)*/
    u32i = 0;
    while(u32i < 4)
        /* Clear Capture Falling and Rising Indicator */
        PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH | PWM_CAPTURE_INT_RISING_LATCH);
        /* Get Capture Falling Latch Counter Data */
        u32Count[u32i++] = PWM_GET_CAPTURE_FALLING_DATA(PWM, u32Ch);
        /* Wait for Capture Rising Indicator */
        while(PWM_GetCaptureIntFlag(PWM, u32Ch) < 1);
        /* Clear Capture Rising Indicator */
        PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_RISING_LATCH);
        /* Get Capture Rising Latch Counter Data */
        u32Count[u32i++] = PWM_GET_CAPTURE_RISING_DATA(PWM, u32Ch);
    u16RisingTime = u32Count[1];
    u16FallingTime = u32Count[0];
    u16HighPeriod = u32Count[1] - u32Count[2];
    u16LowPeriod = 0x10000 - u32Count[1];
    u16TotalPeriod = 0x10000 - u32Count[2];
    printf("\nPWM generate: \nHigh Period=7199 ~ 7201, Low Period=16799 ~ 16801, Total Period=23999 ~ 24001\n");
    printf("\nCapture Result: Rising Time = %d, Falling Time = %d \nHigh Period = %d, Low Period = %d, Total Period = %d.\n\n",
           u16RisingTime, u16FallingTime, u16HighPeriod, u16LowPeriod, u16TotalPeriod);
    if((u16HighPeriod < 7199) || (u16HighPeriod > 7201) || (u16LowPeriod < 16799) || (u16LowPeriod > 16801) || (u16TotalPeriod < 23999) || (u16TotalPeriod > 24001))
        printf("Capture Test Fail!!\n");
    else
        printf("Capture Test Pass!!\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable XT1_OUT(PF.0) and XT1_IN(PF.1) */
    SYS->GPF_MFP &= ~(SYS_GPF_MFP_PF0_Msk | SYS_GPF_MFP_PF1_Msk);
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable external 12MHz XTAL, internal 22.1184MHz */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk);
    /* Enable PLL and Set PLL frequency */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(2));
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable PWM module clock */
    CLK_EnableModuleClock(PWM01_MODULE);
    CLK_EnableModuleClock(PWM23_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Select PWM module clock source */
    CLK_SetModuleClock(PWM01_MODULE, CLK_CLKSEL1_PWM01_S_HXT | CLK_CLKSEL2_PWM01_EXT_HXT, 0);
    CLK_SetModuleClock(PWM23_MODULE, CLK_CLKSEL1_PWM23_S_HXT | CLK_CLKSEL2_PWM23_EXT_HXT, 0);
    /* User can select PWM module clock source from LIRC as below */
    //CLK_SetModuleClock(PWM01_MODULE, CLK_CLKSEL1_PWM01_S_LIRC | CLK_CLKSEL2_PWM01_EXT_LIRC, 0);
    //CLK_SetModuleClock(PWM23_MODULE, CLK_CLKSEL1_PWM23_S_LIRC | CLK_CLKSEL2_PWM23_EXT_LIRC, 0);
    /* Reset PWMA channel0~channel3 */
    SYS_ResetModule(PWM03_RST);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD);
    /* Set GPA multi-function pins for PWMA Channel 0 and Channel 1 */
    SYS->GPA_MFP &= ~(SYS_GPA_MFP_PA12_Msk | SYS_GPA_MFP_PA13_Msk);
    SYS->GPA_MFP |= SYS_GPA_MFP_PA12_PWM0 | SYS_GPA_MFP_PA13_PWM1;
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main(void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("+------------------------------------------------------------------------+\n");
    printf("|                          PWM Driver Sample Code                        |\n");
    printf("|        |\n");
    printf("  This sample code will use PWMA channel 0 to capture\n  the signal from PWMA channel 1.\n");
    printf("  I/O configuration:\n");
    printf("    PWM0(PA.12 PWMA channel 0) <--> PWM1(PA.13 PWMA channel 1)\n\n");
    printf("Use PWMA Channel 0(PA.12) to capture the PWMA Channel 1(PA.13) Waveform\n");
    while(1)
        printf("Press any key to start PWM Capture Test\n");
        getchar();
        /* Set the PWMA Channel 1 as PWM output function.                                               */
        /* Assume PWM output frequency is 250Hz and duty ratio is 30%, user can calculate PWM settings by follows.
           duty ratio = (CMR+1)/(CNR+1)
           cycle time = CNR+1
           High level = CMR+1
           PWM clock source frequency = __HXT = 12000000
           (CNR+1) = PWM clock source frequency/prescaler/clock source divider/PWM output frequency
                   = 12000000/2/1/250 = 24000
           (Note: CNR is 16 bits, so if calculated value is larger than 65536, user should increase prescale value.)
           CNR = 23999
           duty ratio = 30% ==> (CMR+1)/(CNR+1) = 30%
           CMR = 7199
           Prescale value is 1 : prescaler= 2
           Clock divider is PWM_CSR_DIV1 : clock divider =1
        /* set PWMS channel 1 output configuration */
        PWM_ConfigOutputChannel(PWMA, PWM_CH1, 250, 30);
        /* Enable PWM Output path for PWMA channel 1 */
        PWM_EnableOutput(PWMA, 0x2);
        /* Enable Timer for PWMA channel 1 */
        PWM_Start(PWMA, 0x2);
        /* Set the PWMA channel 0 for capture function                                         */
        /* If input minimum frequency is 250Hz, user can calculate capture settings by follows.
           Capture clock source frequency = __HXT = 12000000 in the sample code.
           (CNR+1) = Capture clock source frequency/prescaler/clock source divider/minimum input frequency
           CNR = 0xFFFF
           (Note: In capture mode, user should set CNR to 0xFFFF to increase capture frequency range.)
        /* set PWMA channel 0 capture configuration */
        PWM_ConfigCaptureChannel(PWMA, PWM_CH0, 166, 0);
        /* Enable capture falling edge interrupt for PWMA channel 0 */
        PWM_EnableCaptureInt(PWMA, PWM_CH0, PWM_CAPTURE_INT_FALLING_LATCH);
        /* Enable PWMA NVIC interrupt */
        NVIC_EnableIRQ((IRQn_Type)(PWMA_IRQn));
        /* Enable Timer for PWMA channel 0  */
        PWM_Start(PWMA, 0x1);
        /* Enable Capture Function for PWMA channel 0 */
        PWM_EnableCapture(PWMA, 0x1);
        /* Wait until PWMA channel 0 Timer start to count */
        while(PWMA->PDR0 == 0);
        /* Capture the Input Waveform Data */
        CalPeriodTime(PWMA, PWM_CH0);
        /* Stop PWMA channel 1 (Recommended procedure method 1)                                                 */
        /* Set PWM Timer loaded value(CNR) as 0. When PWM internal counter(PDR) reaches to 0, disable PWM Timer */
        /* Set PWMA channel 1 loaded value as 0 */
        PWM_Stop(PWMA, 0x2);
        /* Wait until PWMA channel 1 Timer Stop */
        while(PWMA->PDR1 != 0);
        /* Disable Timer for PWMA channel 1 */
        PWM_ForceStop(PWMA, 0x2);
        /* Disable PWM Output path for PWMA channel 1 */
        PWM_DisableOutput(PWMA, 0x2);
        /* Stop PWMA channel 0 (Recommended procedure method 1)                                                 */
        /* Disable PWMA NVIC */
        NVIC_DisableIRQ((IRQn_Type)(PWMA_IRQn));
        /* Set loaded value as 0 for PWMA channel 0 */
        PWM_Stop(PWMA, 0x1);
        /* Wait until PWMA channel 0 current counter reach to 0 */
        while(PWMA->PDR0 != 0);
        /* Disable Timer for PWMA channel 0 */
        PWM_ForceStop(PWMA, 0x1);
        /* Disable Capture Function and Capture Input path for  PWMA channel 0*/
        PWM_DisableCapture(PWMA, 0x1);
        /* Clear Capture Interrupt flag for PWMA channel 0*/
        PWM_ClearCaptureIntFlag(PWMA, PWM_CH0, PWM_CAPTURE_INT_FALLING_LATCH);
捕获功能你会使用吗
小夏天的大西瓜| | 2022-12-24 20:37 | 只看该作者
gaoyang9992006 发表于 2022-12-24 17:30
捕获功能你会使用吗
会了会了,其实咱们国产的MCU我发现还是标准函数库用的多,现在STM32都推出HAL库了,但最终还是标准库比较稳定,接受起来更容易
小小蚂蚁举千斤| | 2022-12-30 21:22 | 只看该作者
楼主程序简洁明了,学习到了
中国龙芯CDX| | 2023-1-13 10:58 | 只看该作者
hal库已经出来了,慢慢会向这个转的吧
幸福小强| | 2023-1-13 11:23 | 只看该作者
主要要理解捕获的实现方法,到底在捕什么。
2030
