- void SPI1_Init(void)
- GPIO_InitTypeDef GPIO_InitTypeStruct;
- SPI_InitTypeDef SPI_InitStructure;
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_SPI1,ENABLE);
- /*************************SPI引脚初始化*********************************/
- GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_0); //SCK
- GPIO_PinAFConfig(GPIOA,GPIO_PinSource6,GPIO_AF_0); //MISO
- GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_0); //MOSI
- GPIO_InitTypeStruct.GPIO_Mode=GPIO_Mode_AF ;
- GPIO_InitTypeStruct.GPIO_OType=GPIO_OType_PP;
- GPIO_InitTypeStruct.GPIO_Pin=GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
- GPIO_InitTypeStruct.GPIO_PuPd=GPIO_PuPd_UP;
- GPIO_InitTypeStruct.GPIO_Speed=GPIO_Speed_Level_3;
- GPIO_Init(GPIOA,&GPIO_InitTypeStruct);
- /*************************片选、复位脚初始化*****************************/
- GPIO_InitTypeStruct.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_2 | GPIO_Pin_1; // CSN
- GPIO_InitTypeStruct.GPIO_Speed = GPIO_Speed_10MHz; //
- GPIO_InitTypeStruct.GPIO_Mode = GPIO_Mode_OUT; //
- GPIO_InitTypeStruct.GPIO_OType = GPIO_OType_PP;
- GPIO_InitTypeStruct.GPIO_PuPd = GPIO_PuPd_UP;
- GPIO_Init(GPIOA, &GPIO_InitTypeStruct);
- SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
- SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //串行同步时钟的空闲状态为高电平
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
- SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
- SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16; //定义波特率预分频的值:波特率预分频值为256
- SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
- SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式
- SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
- SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_QF);//配置接收FIFO触发阈值
- SPI_Cmd(SPI1, ENABLE); //使能SPI外设
- //SPIx 读写一个字节
- //TxData:要写入的字节
- //返回值:读取到的字节
- unsigned char SPI1_ReadWriteByte(unsigned char TxData)
- unsigned char retry=0;
- while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET) //等待发送区空
- retry++;
- if(retry>200)return 0;
- SPI_SendData8(SPI1,TxData);
- retry=0;
- while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET) //等待接收完一个 byte
- retry++;
- return (SPI_ReceiveData8(SPI1)); //返回通过 SPIx 最近接收的数据
