[其他ST产品]
# CCS6.0仿真器100v3连接不上SM320F28335
255|0
豌豆爹|  楼主 | 2023-1-5 09:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
C28xx: Error connecting to the target: (Error -233 @ 0x0) The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault. (Emulation package 5.1.450.0)
注:板子本身是好的,我进行CAN刷写底层后发生100v3连接不上问题!
