IAP读写檫均不行
625|7
 楼主| zhuww 发表于 2023-1-15 23:00 | 显示全部楼层 |阅读模式
MA803 IAP错误
pengf 发表于 2023-1-15 23:02 | 显示全部楼层
然后呢?你是怎么应对这个的呢
 楼主| zhuww 发表于 2023-1-15 23:04 | 显示全部楼层
IAP_ADDR=0x3600,IAP读写檫均不行,错在那呢
 楼主| zhuww 发表于 2023-1-15 23:08 | 显示全部楼层
void IAP_Page_Erase(unsigned int IAP_Addr,unsigned char Trigger_Check2)
#if (Xtal_Freq<=6)
     ISPCR=0x03 ;
#elif (Xtal_Freq<=10)
    ISPCR=0x02 ;
#elif (Xtal_Freq<=20)
     ISPCR=0x01 ;
#elif (Xtal_Freq<=40)
     ISPCR=0x00 ;
#endif
    ISPCR = ISPCR | 0x80 ;
   IFADRH = IAP_Addr >> 8 ;                     //IAP Flash Address High Byte
    IFADRL = IAP_Addr & 0xFF ;                   //IAP Flash Address Low Byte
    IFMT = 0x03 ;                                //IAP Flash Mode Table (Erase Mode)
   if (Trigger_Check1==0x55)
       SCMD = 0x46 ;
    else
       IAP_Fail() ;
   if (Trigger_Check2==0xAA)
    {  SCMD = 0xB9 ;
    else
    {  SCMD = 0x00 ;
       IAP_Fail() ;
    Trigger_Check2=0x00;
    ISPCR = ISPCR & 0x7F ;
xxmmi 发表于 2023-1-15 23:10 | 显示全部楼层
先跑官方IAP例程也不行?电压正常吗?
 楼主| zhuww 发表于 2023-1-15 23:12 | 显示全部楼层
好的,我明天去单位试一下,多谢各位大侠了哈
Stahan 发表于 2023-1-19 19:52 | 显示全部楼层
跑官方IAP例程也不行吗?
