[STM32L0]
【经验分享】stm32L0 (一)系统时钟配置
246|0
cr315|  楼主 | 2023-1-16 10:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
MCU为stm32l0系列,时钟配置如下:
  • //时钟系统配置函数
  • //SYSCLK=Fs*PLLMUL/PLLDIV;
  • //Fusb=Fvco/pllq=Fs*(plln/(pllm*pllq));
  • //SYSCLK =
  • //Fs 8M
  • //Fvco: 8M
  • //SYSCLK: 系统时钟频率 8*8/2=32
  • //PLLMUL:倍频 8
  • //PLLDIV:分频系数 2
  • void SystemClockConfig( void )
  •     RCC_OscInitTypeDef RCC_OscInitStruct;
  •     RCC_ClkInitTypeDef RCC_ClkInitStruct;
  •     __HAL_RCC_GPIOH_CLK_ENABLE();
  •     __HAL_RCC_PWR_CLK_ENABLE( );
  •     __HAL_PWR_VOLTAGESCALING_CONFIG( PWR_REGULATOR_VOLTAGE_SCALE1 );
  •     RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;    //高速外部时钟 8M
  •     RCC_OscInitStruct.HSEState = RCC_HSE_ON;            //打开HSE
  •     RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;        //打开PLL
  •     RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;    //设置PLL时钟源
  •     RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL8;            //8倍频
  •     RCC_OscInitStruct.PLL.PLLDIV = RCC_PLL_DIV2;            //PLL VCO输入时钟的分频系数
  •     if( HAL_RCC_OscConfig( &RCC_OscInitStruct ) != HAL_OK )
  •         assert_param( FAIL );
  •     RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK |
  •                                   RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
  •     RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;        //设置系统时钟源
  •     RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;                //AHB分频系数为1 32
  •     RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV8;                //APB1分频系数为8 4
  •     RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;                //APB2分频系数为1 32
  •     if( HAL_RCC_ClockConfig( &RCC_ClkInitStruct, FLASH_LATENCY_1 ) != HAL_OK )
  •     HAL_SYSTICK_Config( HAL_RCC_GetHCLKFreq( ) / 1000 );
  •     HAL_SYSTICK_CLKSourceConfig( SYSTICK_CLKSOURCE_HCLK );
  •     HAL_NVIC_SetPriority( SysTick_IRQn, 1, 0 );
  •     HAL_NVIC_EnableIRQ(SysTick_IRQn);
复制代码
