[PADS] PADS心得改全部元件的字体属性。
623|0
 楼主| forgot 发表于 2023-1-17 14:35 | 显示全部楼层 |阅读模式
    单击鼠标右键,选select components, 再单击右键,选 select all (CTRL+A)。再单击右键,选query/modify (CTRL+Q), part outline width 输入想要的宽度,下面选label, 选Ref. Des. Press the big button under it. 弹出新窗口, input the value you want at size and width. Press OK. Then the size, width , even the part outline width are same.
