[PADS] PADS心得覆铜
875|0
 楼主| forgot 发表于 2023-1-17 14:36 | 显示全部楼层 |阅读模式
      覆铜应该是PADS的一大优点。快了很多。对于焊盘可以选择铜是盖过去(flood over)还是用对角(orthogonal, diagonal)连接。对某一个形状的焊盘只能一种设置。如果有几个圆形焊盘希望铜铺过去,而几个相同的圆形焊盘想用梅花连接。那可以这样。覆铜时preference\thermals\, select the pad and shape, check “ orthogonal” or “diagonal”, then all these shape pads are orthogonal or diagonal connection to the copper. And then, put a copper (铜皮)to the pads you want the copper flood over,and assign the same net to thecopper. Then these pads are flooded over by the copper.
