[活动专区]
【AT-START-F437-测评】2023年第一测评 点灯系列
2360|0
【AT-START-F437-测评】开发环境:KEIL
工具:437开发板,数据线一条
测评内容:首先是搭好的环境点灯,再使LED闪烁,再以200MS流水灯。
1、环境搭建就是安装KEIL,再装安装PACK文件。
2、资料
寄存器:
框架:
3.原理图
4.代码
LED初始化:
void LED_Init(void)
  gpio_init_type gpio_init_struct;
  crm_periph_clock_enable(CRM_GPIOD_PERIPH_CLOCK, TRUE );  /* enable the led clock */
  gpio_default_para_init(&gpio_init_struct);/* set default parameter */
  gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;  /* configure the led gpio */
  gpio_init_struct.gpio_out_type  = GPIO_OUTPUT_PUSH_PULL;
  gpio_init_struct.gpio_mode = GPIO_MODE_OUTPUT;
  gpio_init_struct.gpio_pins =GPIO_PINS_13 |GPIO_PINS_14|GPIO_PINS_15;
  gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
  gpio_init(GPIOD, &gpio_init_struct);
        /*关掉LED*/
        gpio_bits_set(GPIOD,GPIO_PINS_13);
        gpio_bits_set(GPIOD,GPIO_PINS_14);
        gpio_bits_set(GPIOD,GPIO_PINS_15);
LED定义:
#define LED2_GPIO_PORT            GPIOD                                    /* GPIO port */
#define LED2_GPIO_CLK             RCC_AHB_PERIPH_GPIOD                /* GPIO port clock */
#define LED2_GPIO_PIN                                GPIO_PINS_13
#define LED2_ON                        {LED2_GPIO_PORT->clr = LED2_GPIO_PIN;}
#define LED2_OFF                                        {LED2_GPIO_PORT->scr = LED2_GPIO_PIN;}
#define LED2_TOGGLE                                {LED2_GPIO_PORT->odt ^= LED2_GPIO_PIN;}
#define LED3_GPIO_PORT            GPIOD                                    /* GPIO port */
#define LED3_GPIO_CLK             RCC_AHB_PERIPH_GPIOD                /* GPIO port clock */
#define LED3_GPIO_PIN                                GPIO_PINS_14
#define LED3_ON                        {LED3_GPIO_PORT->clr = LED3_GPIO_PIN;}
#define LED3_OFF                                        {LED3_GPIO_PORT->scr = LED3_GPIO_PIN;}
#define LED3_TOGGLE                                {LED3_GPIO_PORT->odt ^= LED3_GPIO_PIN;}
#define LED4_GPIO_PORT            GPIOD                                    /* GPIO port */
#define LED4_GPIO_CLK             RCC_AHB_PERIPH_GPIOD                /* GPIO port clock */
#define LED4_GPIO_PIN                                GPIO_PINS_15
#define LED4_ON                        {LED4_GPIO_PORT->clr = LED4_GPIO_PIN;}
#define LED4_OFF                                        {LED4_GPIO_PORT->scr = LED4_GPIO_PIN;}
#define LED4_TOGGLE                                {LED4_GPIO_PORT->odt ^= LED4_GPIO_PIN;}
LED流水灯:
void LED_Flash(void)
        LED2_ON;
        LED3_OFF;
        LED4_OFF;
        Delay_ms(200);
        LED3_ON;
        LED2_OFF;
        LED4_OFF;
        Delay_ms(200);
        LED4_ON;
        LED2_OFF;
        LED3_OFF;
        Delay_ms(200);
        LED3_OFF;
        LED2_OFF;
        LED4_OFF;
        Delay_ms(200);
LED闪烁:
        void LED_blink(void)
    LED2_ON;
    LED3_ON;
    LED4_ON;
    Delay_ms(100);
    LED2_OFF;
    LED3_OFF;
    LED4_OFF;
    Delay_ms(100);
5.视频
认证:工程师
简介:超越自我,为设计激发灵感和想象。
244
