[其他ST产品]
STM32F0 定时器中断 小白掉进的坑(FreeModbus)Timeout
682|8
9dome猫|  楼主 | 2023-1-30 23:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1)STM32F0有多个定时器,对应多个IRQn
  TIM1_BRK_UP_TRG_COM_IRQn    = 13,     /*!< TIM1 Break, Update, Trigger and Commutation Interrupt           */
  TIM1_CC_IRQn                = 14,     /*!< TIM1 Capture Compare Interrupt                                  */
  TIM3_IRQn                   = 16,     /*!< TIM3 global Interrupt                                           */
  TIM6_IRQn                   = 17,     /*!< TIM6 global Interrupt                                           */
  TIM14_IRQn                  = 19,     /*!< TIM14 global Interrupt                                          */
  TIM15_IRQn                  = 20,     /*!< TIM15 global Interrupt                                          */
  TIM16_IRQn                  = 21,     /*!< TIM16 global Interrupt                                          */
  TIM17_IRQn                  = 22,     /*!< TIM17 global Interrupt                                          */
9dome猫|  楼主 | 2023-1-30 23:55 | 只看该作者
2)通常每个IRQn对应一个zho中断函数
  * [url=home.php?mod=space&uid=247401]@brief[/url]  This function handles TIM14 global interrupt request.
  * @param  None
  * @retval None
void TIM14_IRQHandler(void)
  HAL_TIM_IRQHandler(&Input_Handle);
中断函数里通常会调用HAL_TIM_IRQHandler(&Input_Handle);这个函数来区分是哪一种中断
  * @brief  This function handles TIM interrupts requests.
  * @param  htim TIM  handle
  * @retval None
void HAL_TIM_IRQHandler(TIM_HandleTypeDef *htim)
  /* Capture compare 1 event */
  if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC1) != RESET)
    if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC1) !=RESET)
        __HAL_TIM_CLEAR_IT(htim, TIM_IT_CC1);
        htim->Channel = HAL_TIM_ACTIVE_CHANNEL_1;
        /* Input capture event */
        if((htim->Instance->CCMR1 & TIM_CCMR1_CC1S) != 0x00U)
          HAL_TIM_IC_CaptureCallback(htim);
        /* Output compare event */
        else
          HAL_TIM_OC_DelayElapsedCallback(htim);
          HAL_TIM_PWM_PulseFinishedCallback(htim);
        htim->Channel = HAL_TIM_ACTIVE_CHANNEL_CLEARED;
  /* Capture compare 2 event */
  if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC2) != RESET)
    if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC2) !=RESET)
      __HAL_TIM_CLEAR_IT(htim, TIM_IT_CC2);
      htim->Channel = HAL_TIM_ACTIVE_CHANNEL_2;
      if((htim->Instance->CCMR1 & TIM_CCMR1_CC2S) != 0x00U)
      else
  /* Capture compare 3 event */
  if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC3) != RESET)
    if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC3) !=RESET)
      __HAL_TIM_CLEAR_IT(htim, TIM_IT_CC3);
      htim->Channel = HAL_TIM_ACTIVE_CHANNEL_3;
      if((htim->Instance->CCMR2 & TIM_CCMR2_CC3S) != 0x00U)
      else
  /* Capture compare 4 event */
  if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC4) != RESET)
    if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC4) !=RESET)
      __HAL_TIM_CLEAR_IT(htim, TIM_IT_CC4);
      htim->Channel = HAL_TIM_ACTIVE_CHANNEL_4;
      if((htim->Instance->CCMR2 & TIM_CCMR2_CC4S) != 0x00U)
      else
  /* TIM Update event */
  if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_UPDATE) != RESET)
    if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_UPDATE) !=RESET)
      __HAL_TIM_CLEAR_IT(htim, TIM_IT_UPDATE);
      HAL_TIM_PeriodElapsedCallback(htim);
  /* TIM Break input event */
  if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_BREAK) != RESET)
    if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_BREAK) !=RESET)
      __HAL_TIM_CLEAR_IT(htim, TIM_IT_BREAK);
      HAL_TIMEx_BreakCallback(htim);
  /* TIM Trigger detection event */
  if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_TRIGGER) != RESET)
    if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_TRIGGER) !=RESET)
      __HAL_TIM_CLEAR_IT(htim, TIM_IT_TRIGGER);
      HAL_TIM_TriggerCallback(htim);
  /* TIM commutation event */
  if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_COM) != RESET)
    if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_COM) !=RESET)
      __HAL_TIM_CLEAR_IT(htim, TIM_FLAG_COM);
      HAL_TIMEx_CommutationCallback(htim);
9dome猫|  楼主 | 2023-1-30 23:59 | 只看该作者
在这个函数里根据不同的中断,调用不同的回调函数,像最基本的计时中断,调用HAL_TIM_PeriodElapsedCallback(htim);
问题来了:当我的程序需要用多个di开始定时器时,而且有相同的中断。开始我以为可以在HAL_TIM_IRQHandler(&Input_Handle);后面写自己的处理代码
//其他处理代码
9dome猫|  楼主 | 2023-1-31 00:00 | 只看该作者
6)但是,在使用Freemodbus的时候FreeModbus用到的定时器在HAL_TIM_PeriodElapsedCallback(htim)中执行了TIMERExpiredISR();这个函数。
9dome猫|  楼主 | 2023-1-31 00:02 | 只看该作者
7)当我用到另一个别的定时器的的时候,因为我在HAL_TIM_PeriodElapsedCallback(htim)这个函数里没有区分是哪个定时器产生的中断,所以当其他定时器产生中断时也顺便执行了属于FreeModbus的这个TIMERExpiredISR();处理函数。
8)这样就导致了一个奇怪的xian现象:只有我一启动别的定时器。主机Modbus Poll的时候就会出现Timeout的情况。
在HAL_TIM_PeriodElapsedCallback(htim)中区分zh中断来源之后,问题就解决了。
9)ken坑啊,都怪对库的执行sh顺序不了解。
